Utra low sulfur VS High sulfur dyed ?
   / Utra low sulfur VS High sulfur dyed ? #31
I don't want to mess up a new tier 4 engine and as my wife calls it a $17k lawnmower
Your tractor, I mean $17K lawnmower (props to your wife for comedy), has a Tier 4 interim engine, same as most compact and subcompact tractors have had since about 2008. It's not one of the recent Tier 4 final engines (which are only required over 26HP). So don't worry about the Tier 4 final issues you may have been reading about.
Last question. I had the dyed 15ppm ULSD #2 delivered today. $2.14 @ gal.
What is the difference of dyed 15ppm ULSD #1 other than the price ?
And is the #2 ok for the Tier 4 engines?
   / Utra low sulfur VS High sulfur dyed ? #34
ULSD #2 is diesel and is what a tier 4 tractor runs on.
ULSD #1 is sometimes called kerosene or at the pump may be called #1 diesel. In cold country #1 or #2 can be used for diesels.
I run #2 year round with Power Service additive to prevent fuel gelling. I usually don't have that problem with the tractor kept in a garage in winter when not in use.
ULSD #2 is diesel and is what a tier 4 tractor runs on. ULSD #1 is sometimes called kerosene or at the pump may be called #1 diesel. In cold country #1 or #2 can be used for diesels. I run #2 year round with Power Service additive to prevent fuel gelling. I usually don't have that problem with the tractor kept in a garage in winter when not in use.
Thanks,
I believe I know all I needed to know about the #2 dyed diesel & #1 diesel/ kerosene. But wait!.... Last week I bought K1 kerosene at $5.99 per gal. Can I safely use #1 dyed diesel for a portable kerosene heater?
   / Utra low sulfur VS High sulfur dyed ? #36
Thanks,
I would say yes. My portable kerosene heater (salamander) can use #1 or 2. There was a sticker on mine when I bought it that said to use #1 or 2 fuel. K1 around here is high in price also. I use #2 in mine and it runs fine.
   / Utra low sulfur VS High sulfur dyed ? #37
This is still confusing to me as well. Local stations can't seem to tell me that their dyed fuel is ULSD. Their pumps have stickers as follows:
As a result, I'm still buying on road diesel.
   / Utra low sulfur VS High sulfur dyed ? #39
Thanks,
you've done well beyond the call of duty on this fuel topic....hopefully you can rest better at nightfall given responses.... best regards to ya & use of machine. btw have you decided on a fuel supplement or going as is since you're so concerned on fuel quality? there is never a lack of opinion on this topic... :)
I got a gallon of stabil for diesel. It's supposed to cover pretty much everything.
Sent from the mountains
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
American Farmworks 15 Mile Fence Controller (A51573)
American Farmworks...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2017 Bobcat E20 Excavator (A52384)
2017 Bobcat E20...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
NEW Fork Extensions (A53002)
NEW Fork...
