How much HP needed for a 72" belly mower?
   / How much HP needed for a 72" belly mower? #11
Is the HP the same at the mid PTO and the rear PTO?
Not sure I understand the question. The engine powers both but the mid pto is geared to run approx 2000 rpm, the rear has 2 speed options one is 540 and the other option is higher speed rpm but I don't recall.
   / How much HP needed for a 72" belly mower? #12
So both the mid and rear PTO are 19 HP for the B2620? For some reason I have always kind of assumed the mid PTO would be 26 HP and the rear PTO would be 19 HP on the B2620 for example, but I guess they are both 19HP.
   / How much HP needed for a 72" belly mower? #13
I'm betting the rear pto has more HP/torque than the mid, it's all about the gearing!
SR
   / How much HP needed for a 72" belly mower? #14
Looking at Kubota parts on line: There is no 72mmm listed in the parts. Just a 54" and 60".:rolleyes:
   / How much HP needed for a 72" belly mower? #16
I just don't want to be under powered after suffering with a 42" 19HP cub cadet for 8 yrs. In tall grass i have to go 1 mph then go over it a few more times before it would cut it. I'm surprised that 19.5 pto is enough for a 72" deck.
There will be no comparison between your 19hp gas Cub and what you are now considering. A 60" pto drive shaft deck on the B2620 will be way more productive and powerful than your Cub 42" deck. Again no comparison. For a 72" deck you probably would have to jump up one size to a B3200. Or the new B2650 if no b3200's are available.
   / How much HP needed for a 72" belly mower? #17
I still think it was a 60 " belly mower, not a 6'.
B2620 max belly deck is 60 inch. Local dealer had one for sale with a 72 inch rear finish mower.
B2650 and B3350 have 72 inch belly mowers. Is there any differance in the B2650 and B3350 besides the extra HP?
   / How much HP needed for a 72" belly mower? #19
My 17 hp B7200 does fine with a 60 belly mower. My F2560 is 25 hp with a 60 inch deck. I have yet to find grass that will bog this mower down. If you can push it over it, it will cut it. Diesel power is no comparison to gas.
   / How much HP needed for a 72" belly mower? #20
Ok, it was not a 72" belly mower on the B2620 but a rear finish mower. I would test drive the unit and mow some tall thick grass. It would probably be fine.
I don't have experience with the 2650 or 3350. Check specs on Kubota.Com.
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2018 John Deere Z997R (A53317)
2018 John Deere...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
66in Bucket Skid Steer Attachment (A55851)
66in Bucket Skid...
Yamaha Cart (A55853)
2003 Sailfish 188 18ft. Boat with S/A 20ft Boat Trailer (A55853)
2003 Sailfish 188...
