Yanmar 2010 can it handle it?
   / Yanmar 2010 can it handle it? #31
My Ym2000 doesn't smoke much either. Only when I Start it up and when I Bog it down so much it's about to Stall out. Been like that for 8yrs. and almost 500Hrs. by the Tach. Awhile back I put it to work the hardest since I owned it, It smoked and blew out alot of Carbon Bombs when It was Loaded Down and close to stalling. It still starts and runs like it always has. No smoke or oil loss.
   / Yanmar 2010 can it handle it? #32
Yea there is not really black smoke till you load it down hard. I am not talking about normal bushhogging. Even cutting tall waist deep grass i dont smoke. Its when i am in the wrong gear or its pulling it down to stall i get the smoke. I will smoke if i stomp the throttle down when just driving for a second or two till up to speed.
I too have no oil loss as well.
Sounds like mine is the same as you guys is. Thxs for all the help
   / Yanmar 2010 can it handle it? #34
Mine don't blow much smoke either. I get more smoke from my Cummins
   / Yanmar 2010 can it handle it? #35
Type in "Diesel lope" in YouTube and have a look, then you'll see cummins and the like coalin' like a steamtrain......:eek:
Git a question about the governer someone brought up. I noticed today that while driving up a 10 ft long hill the tractor kinda acted like it wanted more juice but didnt rev any. Should it? Kinda like a mower revs alittle when u hit a thick part of grass
   / Yanmar 2010 can it handle it? #37
Doesn't seem to me these grey Yanmar governors are near as sensitive as many of the old gas engine governors. Not being there I can only say if your rpm drop was significant then the governor should have responded.
   / Yanmar 2010 can it handle it? #39
Just thinking out loud here - These have standard pto rpm about 2200 rpm, and a torque peak at 1800 rpm.
So losing a little rpm when the going gets tough doesn't mean its going to stall, its just going to run a little slower, but with adequate torque to keep moving.
So this 200 rpm drop is harmless.
Ok, that's theory (as I see it). Makes sense?
   / Yanmar 2010 can it handle it? #40
Makes sense to me but also seems a properly operating governor should respond with a 200rpm loss. Does it respond at any rpm loss? 300? 400?
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
Schulte XH1500 Series 4 Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
2012 Dixie Chopper Magnum 2460 60in Zero Turn Commercial Mower (A59228)
2012 Dixie Chopper...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
