AR 15
   / AR 15 #41
Eddie, Last week I was talking to my friend who is a State Trooper and owns a gun store. He sells a lot of AR's and had just got in his first Ruger AR-556. He was very impressed by the gun and for what you get with it being under $600. Windham Weaponry also makes good AR's for the money. When you get one buy some Magpul Pmags. For $11-12 each they are a good investment.
   / AR 15 #42
Those Rural king prices looked yummy!
   / AR 15 #43
Hmm, do I sense an impending shortage of .223 and 5.56 rounds in the near future :)
   / AR 15 #44
Quality or good deal????? bushmaster is on the low end price tells you. they are 400 or more less then other brands for a reason...
with a 223 you can shoot 556 but 556 is a lesser load(NATO) and will not shoot as well as the 223
with a 556 you can NOT shoot 223
   / AR 15 #45
with a 556 you can NOT shoot 223[/QUOTE
   / AR 15 #46
Bit late to the thread, but have spend countless hours reading and researching this very same thing over the past 6 months, so I'll offer up what I can.
For starters, I wouldnt call any of them cheap junk. They meet mil spec, and do as they were designed. However, some cost more because they have more features to offer, or better accessories, or better name (colt).
First you need to decide weather you want piston operated, or direct impingement (DI). All other things being equal, DI guns are cheaper. They are a little dirtier, fowl the bolt a little more but are alot cheaper. Military guns are DI FWIW. Piston operation is not a military thing, therefore no mil spec to that. And have read that not all piston components between MFG's are interchangeable. Whereas Anything on Any DI mil-spec gun is interchangeable.
Next, decide what length system you want. There are 3 different types, Carbine, Mid-lenght, and rifle. This has to do with the lenght of the gas tube, (where the port in the barrel is). IIRC, Carbine is 7", Mid is 9" and rifle is 11". This effects how the gun "feels". If you pull off hot gasses at the 7" point, they are under alot more pressure, as is the case you are trying to eject than at the 11" point. Many folks may not even notice a differnce, but the result is a carbine feels more "violent" in its action and cycling than a rifle length. A mid length is an in-between.
Third, decide what barrel length you want. The reason for carbine length gas systems is for shorter barrels. There needs to be enough barrel forward of the gas port for the gun to function. That cant be done on a short barrel and rifle length system. Barrels have to be at least 16". If you have future plans that may include changing flash suppressors, get one that actually has a 16" barrel. Some of them have a 14.5" barrel from the factory, and they have to pin (otherwise make permanent) the flash suppressor to get the 16" length and you cannot change it later.
Fourth thing to consider is the barrel. There is ALOT that goes into barrel, and lots of acronyms and hard to get it straight. Like M4 barrel, or A2 barrel. You can google something like "ar15 barrel profile differences" and see tons of pics. But an AR barrel isnt just a simple barrel like a rifle. IT is a complex piece that is thin is some spots, thicker in others, steps and shoulders for accessories like a grenade launcher (not that we need to worry). But probably more important than profile is material. There are basically 3. 4140, 4150, and Stainless. Then a lining. You can have a barrel that isnt lined, chrome lined, or nitrided. The nitrided is claimed to be harder and better than chrome, and more accurate since it isnt really a coating, rather a hardening treatment that dont change the dimensions of the barrel/lands. Chrome 4150 is mil spec. 4150 is better than 4140.
Now there is alot of back and forth on barrel material and lining. Military uses 4150 because it is a little stronger, but when really hot, it is quite a bit stronger. But who we kidding, Plain 4140 has worked for YEARS for barrels. So this is one of them things that the "cheap" stuff usually has 4140 non-lined barrels. Or even 4150 but unlined. Where the more expensive stuff is lined or nitrided 4150.
Beyond all that is just accessories. And thats where more of the A2 and M4 jargon comes in. Fixed or collapsable stock, carry handle or flat top, etc. Its just accessories and personal preference at this point.
There are probably 10+ guns in the $650 or less range that are GOOD guns. They lack some features that make the whole gun mil spec to shave some cost. Some dont have a dust cover, some dont have forward assist, no chrome lining, etc. But they are still excellent and reliable guns.
Delton sport
S&w MP Sport
Rugar AR556
Core-15 scout
DPMS has a few models in this price range
Bushmaster
All the lower cost guns will be DI operation and most will be carbine length gas system.
There are TONS of manufactures out there making good quality AR-15's. If you have a specific question about one in general, search or look it up or ask here. But its really hard to go wrong with any off-the-shelf AR. They all make good brands and different configurations in may different price ranges. You just have to figure out what features are important to you, and what you want to spend, and see if the two Jive.
And as mentioned, you can always do a custom build to get exactly what you want. I have a DPMS and a Core 15, but just bought a few stripped anderson lowers. You can get so much more for your money building, but the re-sale is tough on a custom gun. But if you buy an off the shelf gun, and decide you want something different, they dont loose their value much. I see alot for sale on arms list with "only 100rnds shot" and they are asking more than I can buy new for.
   / AR 15 #47
That is WRONG and you should edit or delete that post before someone reads it and believes it.
556 rounds are allowed a higher chamber pressure and as such, built to withstand it. 223 is not.
A 223 can SAFELY be shot in a 556 chamber allthough it might not be as accurate.
A 556 CANNOT be shot safely in a 223 chamber as there is potential to exceed the chamber pressure rating
   / AR 15 #48
That is a good price. I would definitely check it out in person. Haven't owned a Bushmaster and haven't looked at this rifle in person. It might make a good 'starter' rifle that you can upgrade/customize to your or her liking.
Some of the adjustable stocks are 'wiggly' as they don't have a positive clamp on the buffer tube. Adjust that stock and see how much slop there is and whether or not it bothers you. I use and like the Magpul CTR as it has a friction lock that clamps on the buffer tube after you adjust the stock. This gives the stock a nice solid feel like a typical rifle. At $60 the CTR or similar is something you can upgrade to later so not a deal breaker.
Lots of different grip styles and materials. This grip may actually be OK for your wife but I would try a couple rifles with different grips. They will probably have some Magpul and maybe other brand accessories so see if they had different grips on the shelf. See what she likes/fits her hand best. The grip is another thing easily changed out.
That forend (hand guard) is pretty short. May work for her, may not work for you if you like to grip your rifles further out. You can upgrade to other styles/materials that are 'drop ins' but if you want to go to a longer or free-floating style it may involve changing the barrel nut and other more involved work on the rifle. A hand guard with rails will let you add more accessories and sights to the rifle. In my mind a SHTF rifle is a little like a 3-gun rifle in that you would want to be able to engage long-distance and up-close targets quickly. A hand guard with a rail at 45 degrees lets you put your main optic on the receiver and then a holographic on the hand guard off to the side. This is for super-up-close-point-and-shoot. I find giving your rifle a slight twist is a lot easier than trying to raise your head up to look through a holographic mounted on top of your scope. Different hand guards can run from say $30 up to $200 or so.
So keep in mind that cheaper is... well... cheaper. Buying a $600 rifle might not make as much sense once you factor in the cost of upgrades. On the other hand you can upgrade it later so your upfront cost is not as high.
As we approach _next_ November prices and availability might not be what they are now. So for anyone sitting on the fence about buying one I would buy sooner rather than later.
   / AR 15 #49
Agree 100%
Magpuls are much better than the OEM aluminum magazines!
   / AR 15 #50
May have already been said, but bears repeating. One thing that is nice about Rugers (at least SOME of them like the Mini-14 RANCH (not the Target)) is that the chambers are specifically designed for BOTH 5.56 and .223. I believe that this is what's known as the "Wylde" chamber, but I also believe that Ruger won't explicitly confirm that that's exactly what it is. They probably just call it "proprietary". I can't find anything on the Ruger website to confirm or deny, just that their .223/5.56 chambers are suitable for both. The Wylde chamber just has a bit more leade (chamber length gap between the bullet ogive and the start of the rifling). So you give up a tiny bit of accuracy, but can safely use either round.
- Jay
2005 MACK GRANITE GU713 DAY CAB (A51222)
2005 MACK GRANITE...
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
DEERE 250 SKID STEER (A51242)
DEERE 250 SKID...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52128)
Koyker Loader...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
