Aluminum trailers
   / Aluminum trailers #1
MFWD
South Mountain, Pennsylvania
2002 New Holland TC35D with cab, a 2007 New Holland Skid Steer and a 1970's 154 Cub Lo-Boy, 2016 John Deere XUV 550 Gator
Hello,
I just bought a new 2016 John Deere XUV 550 Gator. I had to borrow my sister-in-law's 5' x 8' utility trailer to bring it home. My 4' x8' trailer was too small in width. Actually, the 5' x8' was barely long enough.....the wheel was almost centered over the rear edge. I had it strapped in so tight that it didn't move 1/8" !!!!! So, I think I would like to buy a bigger trailer than my 4' x 8' one. I was thinking about a 5.5' x 10' aluminum utility trailer. Mostly for the 300 pounds saving in weight. I can get one that size at Tractor Supply for $1799.00....about $500.00 more than a steel one of the same size. I will probably pull it and the Gator with my 2008 4- door Jeep Wrangler. It doesn't have the new upgraded HP engine....it still has the 202 HP engine. Not a lot of power, but I know it can do the job. But that is why I'm thinking about going aluminum rather than steel. So if any of you guys have an aluminum utility trailer, can you tell me why you went that way and if you are happy with it. Is there anything special to know about an aluminum one as compared to a steel one ?? Can you ratchet strap things down and not bend the aluminum ??? Thanks ahead of time for all your help !!!!!
MFWD
   / Aluminum trailers #2
Paint it so it isn't as much a thief magnet.
They even steal aluminum highway guardrails around here.
Bruce
   / Aluminum trailers #3
I don't care much for the aluminum trailers. You better check the axel ratings. They are pretty light on the aluminum trailers. The aluminum trailers I have seen don't have brakes either. I don't want a trailer that you have to put plywood down to prevent it from getting scratched. The last time I used my lawnmower trailer was to haul the grapple to the shop. It wasn't kind to it and scared up the wood decking pretty good.
   / Aluminum trailers #4
I am on my second Legend brand 6'X12' high side utility trailer, and would never own a steel one in Michigan. The trailer weighs 740 pounds and the Dexter axle is rated at 3,000 pounds. The sides and deck are 5/4" treated pine and the entire unit is super strong, and it has a ramp gate that tilts down. The reason I am on my second one as I sold the first to my brother who was always borrowing it. You pay a premium for aluminum but will always get it back when resale time comes. My '04 Lesabre can easily pull this trailer and has 1200 pounds of cargo capacity in it before it exceeds the 2000 pound tow rating of the car.
   / Aluminum trailers #5
Bruce
Painting aluminum.....:laughing: you must be kidding the reason to buy aluminum is so you DON'T have to paint it !!!!! All you need do is INSURE IT !!!!! Mine costs me $37 a year to insure. And only a complete moron would sell an aluminum trailer for scrap !!!!!
   / Aluminum trailers #6
I have a 6x12' Triton APT 610 with electric brakes. I wish I had painted it when I first got it. It was pristine, shinny and smooth . One trip up thru the snow and road salt to the Upper Peninsula to haul my brothers new Mule utv, it was all pitted up. Mine has a 5/4 wood deck and weighs 705 lbs. Tracks great. I modified my rear ramp after that and cleaned and painted the frame with aluminum color paint. It will take a lifetime or two to oxydize thru, but it's easy when it's new and clean. Had a steel one before, wouldn't go back.
   / Aluminum trailers #7
I own a 6X12 aluma aluminum trailer.The 2 downfalls I see are the lighter axle and if you live where they spread salt on the roads like they do here in Michigan it pits the heck out of the trailer.
   / Aluminum trailers #8
Hello, I just bought a new 2016 John Deere XUV 550 Gator. I had to borrow my sister-in-law's 5' x 8' utility trailer to bring it home. My 4' x8' trailer was too small in width. Actually, the 5' x8' was barely long enough.....the wheel was almost centered over the rear edge. I had it strapped in so tight that it didn't move 1/8" !!!!! So, I think I would like to buy a bigger trailer than my 4' x 8' one. I was thinking about a 5.5' x 10' aluminum utility trailer. Mostly for the 300 pounds saving in weight. I can get one that size at Tractor Supply for $1799.00....about $500.00 more than a steel one of the same size. I will probably pull it and the Gator with my 2008 4- door Jeep Wrangler. It doesn't have the new upgraded HP engine....it still has the 202 HP engine. Not a lot of power, but I know it can do the job. But that is why I'm thinking about going aluminum rather than steel. So if any of you guys have an aluminum utility trailer, can you tell me why you went that way and if you are happy with it. Is there anything special to know about an aluminum one as compared to a steel one ?? Can you ratchet strap things down and not bend the aluminum ??? Thanks ahead of time for all your help !!!!! MFWD
Consider a 12 foot long trailer. Good luck
   / Aluminum trailers #9
Plus one on the salt issue!
   / Aluminum trailers #10
I have an aluminum 6x10 Aluma utility trailer, 3000lb capacity, no brakes. Weight and ease of maintenance are it's pros. As others have said, road salt is a big enemy along with galvanic corrosion where steel fasteners penetrate the aluminum.
I went over it and isolated all of the screws and bolts on the lights with what I call top hat nylon washers (McMaster/Carr) that keep the steel from touching the aluminum. That was 12 years ago and have never had an electrical issue with lights.
I think the empty trailer weighs 440 pounds and my old V6 Jimmy doesn't know it's back there WHEN it's empty.
It is also very easy to move around by hand.
Werner 28ft Fiberglass Extension Ladder (A57454)
Werner 28ft...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
SUV (A59231)
SUV (A59231)
Champion UH130B High Temperature Commercial Dishwasher (A56860)
Champion UH130B...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
