Need help on Right Tractor For a Grapple.
   / Need help on Right Tractor For a Grapple. #11
Just for reference, I have a 25 horse powered L series Kubota tractor with a grapple for 23 acres of wooded, steep terrain. It does fine for my needs. I really don't need more horse power as much as I need weight. Loaded rear tires and counter weight off the 3 point is a must with a grapple.
   / Need help on Right Tractor For a Grapple. #12
There is no urgency for the purchase at my leisure. Budget is flexible, just concerned as I started at 19K now looking at around 30K+. Mostly hardwoods (oak, hickory, and some clusters of short and Virginia pine) and the short needled pine are the weakest and most prone to fall. The land used to be a tobacco farm about 50+ years ago. Picture below of what it looks like and what has fallen and would like to move.
View attachment 452293View attachment 452294View attachment 452295View attachment 452296
Ain't nothing there I could not pick up with my little 35 horse tractor and small grapple. All day every day.
   / Need help on Right Tractor For a Grapple. #13
These are very important points. You need weight. I have the loaded rear tires, and keep 800+ on the 3pt when doing loader work.
   / Need help on Right Tractor For a Grapple. #14
Kubota MX4800, Done everything I've asked of it.
   / Need help on Right Tractor For a Grapple. #15
Pretty much what everyone else has said, my brother has a grapple on his Kioti CK27 and I have one on my L5740HSTC as well as M8540HDC and all work well.
The whole Kubota, Kioti, MF etc. is junk is ridiculous all make good machines.
   / Need help on Right Tractor For a Grapple. #17
   / Need help on Right Tractor For a Grapple. #18
Kubota is notorious for being light. But then it's always easier to put pounds on than take them off.
And OP - take a serious look at Ted's grapples from Everything Attachments, they are constantly evolving.
   / Need help on Right Tractor For a Grapple. #19
Don't feel pressured to escalate your budget. Stay with an amount you are comfortable with. A small 20hp CUT with appropriately light grapple and a chain saw to get stuff to a size it can handle will do most jobs. Going larger from there just means less cutting.
Small machines have a maneuverability advantage. Larger machines have a stability and ground clearance advantage. I've found these cancel each other out in the woods. I can get some paths with my 20hp where my 45 hp wont fit. I can go other routes with my 45 hp that the 20hp doesn't have the stability or ground clearance for. I've been able to get to anything I want to get to with either of them, although it may be with different approaches.
If you have any real big logs or rocks to move, you may need a grapple that opens wider, which will probably also be heavier, which means a larger machine.
I suggest you just go out and start looking at machines within a budget that you feel comfortable with. That may help you hone in on what you like. My 20 hp will do 90% of the jobs I do with my 45hp - just takes more of my time and energy. I'm sure 70hp UT would be that much faster. However, I never feel like I'm wanting for more with the 45HP tractor. I always wanted for more with the 20HP tractor. I skipped the 30 hp range because at the time I was shopping, the loader performance on the 40+hp tractors was much better than those in the 30hp range and I didn't want to buy a 30 something hp tractor and still want more.
Since this is your first tractor, it will be hard for you to know what would really work well for you on this property. As you get more experience with any tractor and with your property, you will come to know what you really want in a tractor (or other machine). For this reason, I think it really makes sense to to keep the budget reasonable and buy a used tractor with QA loader. This will give you the experience to know what you really want before you spend big money. If you buy and sell well, you won't loose much if anything on a used tractor.
   / Need help on Right Tractor For a Grapple. #20
Now that's just down right tractor ****!
I've always thought the MX series was one of the better looking tractors! How do you make the pictures appear big in the thread rather than having to click on them to open?
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
2018 Kubota U17 (A53317)
2018 Kubota U17...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
Cummins DGCB 60 kW Standby Diesel Generator (A56857)
Cummins DGCB 60 kW...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
