Loader Flipped my L48 Kubota
   / Flipped my L48 Kubota #111
I'll let the OP make his own decisions, hope he keeps us updated, even if he turns out to have additional problems that could have been prevented.
   / Flipped my L48 Kubota #112
As I re-call the OP only wanted advise on why he couldn't shut his tractor off, after that he's been showing us what he's doing, I for one appreciate that and like it. Advise is nothing more then a suggestion and there's no commandment, (Thou must take my advise) so my advise is, change the spark-plugs.
   / Flipped my L48 Kubota #113
I agree. Just hope GmanBart don't see your post....... ;)
   / Flipped my L48 Kubota #114
He wont see it, I have my com set on incognito mode. :thumbsup: I just want to get this tractor fixed.
Got the injectors back from the shop...she is purring like a kitten. No smoke, sounds great. As for doing a total break down...I took a long hard look at those cylinders. Other than some normal discoloration for a machine with 450 hrs, they were perfect. They all came to exactly top dead center. I seen a engine with a bent rod and that piston was almost a half inch from top center. If those cylinders were even a .01" off. I would be breaking it down, but has of now everything seems good. I still may break it down before spring, because a still have to address that hydraulic fluid leak which requires me to break it in have. The fluid is leaking out of that drain nut on the bottom of what i guess would bethe drive shaft housing. The dealership said it sounds like the main seal. I would also like to thank everyone for there input. suppose to hit 60 tomorrow, so i'm gone to take it out and put a couple hours on it to see what it does...lets just hope we don't give soundguy a reason to say "I told you so" Lol.
   / Flipped my L48 Kubota #116
Excellent work, good job!!!:thumbsup:
   / Flipped my L48 Kubota #117
It's credit to you determination... well done!
   / Flipped my L48 Kubota #119
I wish you well.
2003 Big Tex 10PI...
Enmark Z Spray (A53316)
Enmark Z Spray...
TANK MANIFOLD (A55745)
Lone Star dump trailer (A55973)
Lone Star dump...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
