Loader Flipped my L48 Kubota
   / Flipped my L48 Kubota #134
I recently had good luck with this on a head gasket blowing coolant out the overflow tube: Barsleaks
   / Flipped my L48 Kubota #135
I've had friends that used head sealer on flat heads with some success...
   / Flipped my L48 Kubota #136
I added an extra ten pounds of torque and reused the new one.
Are the bolts or studs torque to yield in this application? How much over the upper torque limit is 10 lb•ft. that could be a quite a bit of clamp load if they are fine thread. My luck would have been snapping the thing off or pulling the threads out of the block.
Good luck getting it fixed
I reused a rubber washer (apparently it crushes) on the valve cover of my Suzuki 400 It bottomed the shoulder bolt on the cam holder and striped the threads. Suzuki mentioned that this part wasn't reusable but it was not on the page with the torque specs
   / Flipped my L48 Kubota #138
Another good one Moss!!!!
Yeah, I was making light of it, but we all should think about what we're doing and what could happen. I was around airplanes for most of my life. For just about every incident I ever saw or heard of, it was almost always pilot error. It would just about come down to his error was getting out of bed that day. That's how crucial the pilot is. Equipment operators sometimes gotta have the same reactions and preventative attitude. Gotta anticipate what's gonna or could happen before it does. It could be too late when it's already happening.
   / Flipped my L48 Kubota #139
I'm still foggy how he shut that roaring tractor off, or did it stop by it self?
He stated in his first post that he cut off the fuel supply to shut down the motor.
Sent from my iPhone 2.0 using TractorByNet
   / Flipped my L48 Kubota #140
How does one cut off the fuel supply on a tractor? I thought shutting the key off would of done that.
White 5100 Planter (A59814)
White 5100 Planter...
SKID STEER ATTACHMENT PACKER (A58214)
SKID STEER...
Forklift (A59228)
Forklift (A59228)
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
White 5100 / 6900 Planter (A59814)
White 5100 / 6900...
