What to build? 72ft of 6" wide flat bar
   / What to build? 72ft of 6" wide flat bar
That is a very nice build!:cool: You have some fabricating skills!!:thumbsup::thumbsup:
Thanks Shield. I follow a lot of your posts. You'd probably have a good laugh at some of my methods.
   / What to build? 72ft of 6" wide flat bar #33
I'm sure we have all had to improvise and use unorthodox methods.
I had to flatten out some bends in mounting plates for a backhoe bucket once. Modifying a case bucket to fit a Ford. Ford needs 8" spacing between each pin bracket. Cases uses 10" for the dipper pin and 5" for the bucket. So the case bucket mount pieces have a double bend and needed to be flat.
No press:mur: but had a bottle jack. Put the piece on the bottom of the loader bucket and used the bottle jack against the top.
Have also used a logsplitter as a horizontal press for pressing out stubborn backhoe pins and bushings.
Gotta do what you gotta do to get the job done
Some pictures of the build. I always forget to take pictures.
uploadfromtaptalk1462243580222.jpguploadfromtaptalk1462243601384.jpguploadfromtaptalk1462243618728.jpguploadfromtaptalk1462243629684.jpguploadfromtaptalk1462243640127.jpguploadfromtaptalk1462243691584.jpguploadfromtaptalk1462243713644.jpguploadfromtaptalk1462243727805.jpguploadfromtaptalk1462243756303.jpg
Sorry about the sideways pictures.
   / What to build? 72ft of 6" wide flat bar #36
Nice job Myyaz33.
I'm confused by the small half round discs welded between the SSQA mount and the top tube. What are those for?
Nice job Myyaz33.
Just a gusset for additional support for the center of the ssqa.
   / What to build? 72ft of 6" wide flat bar #38
Never seen that before. I'd think that a full fillet weld across the top of the SSQA (as well as on the bottom) to the top tube would be strong enough.
I got the idea from another build here on tbn. Some have it, some dont. Have no idea if it was necessary, but I didn't want to find out.
   / What to build? 72ft of 6" wide flat bar #40
Understood. I'd say it is unnecessary though as standard buckets don't need more than the fillet and most grapples don't either. Never heard of a ssqa being ripped off a grapple. I wonder if what you saw on other grapple builds was the cleat for attaching one of the upper jaws on a double jaw grapple or on a very wide jaw single. Certainly no harm in having the extra gusset but I'm pretty sure it isn't necessary.
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A50854)
2006 MACK CV...
Unused 2025 CFG QK16R Mini Excavator (A49461)
Unused 2025 CFG...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52128)
2016 KBH...
2007 International 4300 DT466 Refer Truck (A47384)
2007 International...
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
