Backhoe BH76 Backhoe Removal from 20 Series (4520)
   / BH76 Backhoe Removal from 20 Series (4520) #31
Late to the party - again !
About the only thing I can add is that when backing up I "TRY" to sight over the right side pin and keep it over the inside edge of the sub frame.
BTW, mine is an Amerequip model and the rear hook-up lugs are inside the sub frame member.
and of course coming in STRAIGHT helps a lot.
Set safety police watch to OFF !
I use the bucket for final jiggering back/forth so that I can be back there and SEE the hook up lugs while I adjust the stabilizer legs to match the height of the lugs to the pins.
BTW, the hoe is extended and the stabilizers are raised when you are ready to flip the front of the sub frame UP.
The stabilizers are used to flip the front end of the sub frame DOWN.
I did all my own assembly from what was basically a "kit".
Not at all hard, but I did leave a lot of bolts barely snug until everything got shook together.
it sounds like its installed like the ansung, hoe on my branson. i layed under my tractor for about an hr and just staired at the entire under carriage, getting to know it, and hope i never see it again.
   / BH76 Backhoe Removal from 20 Series (4520) #32
Yeah, basically you have two pivot points, so you lift a load that you want to tip one way or the other;
Use the FRONT one (hook pins) to flip the front of the sub frame UP.
Use the rear one (stabilizer legs) to flip the front end of the sub frame DOWN.
It may not be intuitive and obvious at first, since you use the stabilizers to lower the hooks onto the front pivot point.
Anyway, there is no need to use the boom, although tucking it IN may be a good idea if you didn't store it with the transport pins in and if it has leaked down and drooped.
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
2006 Isuzu NPR 16FT Box Truck (A50323)
2006 Isuzu NPR...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2013 John Deere 160G LC Excavator (RIDE AND DRIVE) (A50774)
2013 John Deere...
