No more V8 in F150?
   / No more V8 in F150? #131
There is no substitute for more displacement or increasing the number of cylinders. HS
LOL! And the Earth is flat and the Sun circles the flat Earth... :laughing:
   / No more V8 in F150? #132
It's not 1970. I have owned 6 turbo vehicles since 1999 and all outperformed the bigger displacement options and gave excellent service. Chris
I can assure you as the truck gets bigger and the amount of work to be done increases so does displacement and the number of cylinders to do the work, it's also the least expensive and most reliable way to do more work. HS
   / No more V8 in F150? #133
I can assure you as the truck gets bigger and the amount of work to be done increases so does displacement and the number of cylinders to do the work. HS
Interesting how the Ford 6.7L PowerStroke can do so much more work than the older, larger 7.3L PowerStroke....
Not to mention, the 6.7L makes nearly twice the HP and torque of the old 7.3L.
   / No more V8 in F150? #134
HS lacks clear understanding of simple physics...
   / No more V8 in F150? #135
Interesting how the Ford 6.7L PowerStroke can do so much more work than the older, larger 7.3L PowerStroke.... Not to mention, the 6.7L makes nearly twice the HP and torque of the old 7.3L.
Look at a mining dump truck, locomotive, or ship. To put it simple for dumb dumbs, bigger job, bigger engines, more cylinders. Hate to be so direct, but some people will argue anything. HS
   / No more V8 in F150? #136
Yes some people will (especially when they think they are right even if they are wrong)...
Adding a turbo on a properly designed engine will increase torque/hp over a NA engine of the same size and will not noticeably decrease the expected lifespan.
Take the 7.3L engine.
The IDI version started with 185/338 (hp/torque), then was bumped to 358ft/lb of torque. After that, they added a turbo and got 190hp and 388ft/lb of torque.
They then kept the same displacment but switched to the T444E based engine which put out 210hp and 425lb-ft of torque. Over time, that was increased to 275hp and 525lb-ft of torque.
That's 1.5x the HP out of the same displacement and number of cylinders
As for more cylinders being needed: While thats true at a point (ie ships, trains and mining trucks), you have to get bigger than a semi truck before you need more than 8 cylinders (with the current engines) and Cummins fans would say that you only need 6 cylinders.
Aaron Z
   / No more V8 in F150? #137
Yeah, let's compare a truck capable of towing 30k lbs to one capable of hauling millions of lbs. That makes sense to show that you HAVE to have more displacement and more cylinders to get more power.
Technology has made it possible to get more power, more torque, and better longevity out of smaller engines. If you can't see that, then none of us here can help you.
Wow. I give up. :rolleyes:
   / No more V8 in F150? #138
Its called the Dunning-Kruger effect. What Dunning and Kruger described is that the least knowledgeable have the strongest opinions, because they lack the basic understanding to realise there might be more to the subject than they can comprehend.
in the 70's Diesel engines in passenger cars were a big mistake, and a V6 engine was too small to run some mileage in a full sized car. Well that was what the general public thought. Reason was the Oldsmobile 88 diesel engine, getting only 120hp out of 5.7 liter of engine displacement, was using a gasoline engine bottom end, not able to take the twice as big compression load of a Diesel (the equally strong Mercedes OM 352 engine had about the same displacement, was also built on the tooling of the Opel Blitz gas engine of WW2, and also non-turbocharged.
The OM 352 however, was a very reliable engine, used in commercial vehicles, not in a passenger car.
The V6 engine not big enough for a passenger car, was an idea that occured when the oil crisis led manufacturers to put their entry level cheap compact V6 engines, into full size cars. It wasnt the lack of displacement that made these engines not last, but it was because these engines were designed as a cheap entry level engine, with a lower design life.
Ecoboost is the same thing: Its all about design life. The technology is there to design and build an engine that will last the same as the 5 liter V8. But turbocharging the old Cologne 4 liter V6 of the 60s (which was a bored out version of the 2.3 liter V6 in the German built Taunus) would lead to premature engine failure.
   / No more V8 in F150? #139
I wonder if/when Ford drops the v8 option (far later than 2017 im sure) if they would modify the ecoboost to be capable of burning E85 from the factory. That is one of the major flaws of the eb in my opinion.
   / No more V8 in F150? #140
You do know that the 3.5 ecoboost block has 6 bolt mains and it supports the forged crankshaft with a girdle...right?
I think everyone is trying to get away from anything ethanol...let alone E85.
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2018 Dodge Journey SUV (A59231)
2018 Dodge Journey...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
Unverferth 9250 Auger Wagon (A59814)
Unverferth 9250...
240156 (A56859)
240156 (A56859)
2020 Utility FS2CDHE 45ft. 35 Ton T/A Drop Deck Flatbed Trailer (A60460)
2020 Utility...
