<snip>
120 acres in the southern Appalachians. Approx 16ac hilly fields (bush hog), 4ac lawn and garden (loader/bucket), 3/4 mile gravel driveways (scraper), and the other 100 acres is heavily forested. I heat with wood (OWB), and in the next decade and beyond I hope to thin considerably for long term forest health, as well as sell some timber that was planted for sale by my great-grandfather. A sawmill is on the drawing board, as are firewood and mulch/leaf compost sales; all loader work. So skidding logs needs to happen. My goal is a small, steady trickle of income from several sources the land provides over a long period of time. (Hydropower, maybe solar, etc. blah blah)<snip>,
Frank
Frank - Tell us the dbh and length of the trees you are looking at thinning and milling. That will determine if you can skid them and lift them with XXhp.
For example I've cut some 20" plus trees and was easily able to skid 1 tree section 12' long with a 30 HP Sato. My 23 HP Kubota
B7610 could skid the same if I raised the leading end. With my
M4700 I can virtually plow with the same tree and could probably skid several.
To put the same size log on the sawmill my
B7610 and the Sato could manage it with the 3 point, but not the FEL. The
M4700 can do it with pallet forks on the FEL.
So it depends on how long and how wide you want to cut your trees before you mill them.
Per
the calculator I use a piece of white oak 12 foot long and an average of 20" around weighs about
If it's 30 inches and 12 foot long your looking at about 6,500 lbs.
Now if it's a big tree,
say 5 foot DBH, and 12 foot long it's around 15,000 lbs way to big for the FEL OR 3pt on my tractors. I'd have to borrow a cousins big Massey to drag it.
Like you've written I'm trying to clean up some woods for the future, one tree at a time. I've about 200 acre of mixed hardwood I'm playing on, virtually all the trees are < 24 inches DBH. I've another couple of hundred acres of planted pine, mostly between 8 and 15 years of age, which I'll probably have loggers thin and harvest when the time comes.
