What to do with used oil?
   / What to do with used oil? #31
It is very good to spray on light coats to such as blades on disk, box blades and so forth to prevent rust when shinny from use. Also best place I have found to store a pto pump in 5 gallon bucket of use oil. Have chain on my pumps I just drop over the top of the bucket. Oil on stumps can be interesting, you soak wood in oil to prevent or slow rot but then put in stumps but burning them.
Boy do I understand the benefit of storing chains in oil but while I don't like rusty chains sure don't want to have wet oily chains to work with. For the person who does this do you keep them in the oil or do you pull them out after a dip to have excess drip off?
   / What to do with used oil? #32
I really only store chains I don't use in this fashion. If I have a chain come up missing or need an extra and I need to get one out of storage, I'll dip them in a bucket of old diesel or kerosene to rinse them off. I generally keep a bucket of it around for parts cleaning and fire starting.
   / What to do with used oil? #33
Gave it to friend has oil burning furnace.
   / What to do with used oil? #34
Thanks...you know storing items in oil like that may help them not be so easy to walk off...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
