Wife Destroyed Brand New S240 Sport -- What to Do?
Status
Not open for further replies.
   / Wife Destroyed Brand New S240 Sport -- What to Do? #41
Bang the deck back into shape, then take the wife upstairs and bang her into shape ;) Be sure to point out how "she owes you" :laughing:
Post back your results :thumbsup:
That's a lot of bangin LMAO .
   / Wife Destroyed Brand New S240 Sport -- What to Do? #42
take the spindle out and and turn over, and hammer it out back to the original shape,
decks get bent up and hammers pound them out,
   / Wife Destroyed Brand New S240 Sport -- What to Do? #43
i also would say turn deck over and pound it out, but what keeps that pounding out and that original damage from stretching the original sheet metal??? after doing body work for 35 years there a good chance its stretched. that means the spindles aren't going to be on the same plane and one side will cut angled different than another. also that pounding will weaken that already weak deck at the spindles. after a while those spindles will crack around the bolt holes and you will have to remove it again in the future and get the holes welded up or have a plate installed to reinforce the deck. go to a welding shop and ask for their advice and how much. grass will look like this eccagrated example / \ \ / \ / \
   / Wife Destroyed Brand New S240 Sport -- What to Do? #44
JD must be building some light decks these days. The JD's I've had in the past would support the mower weight if I hung up on a blade. That much damage after one occurrence means the deck has to be thin and light, so on the bright side it should be easy to pound back into shape.
   / Wife Destroyed Brand New S240 Sport -- What to Do? #45
That problem makes bending, clamping, or levering until it is straight look like a better idea than pounding.
Bruce
   / Wife Destroyed Brand New S240 Sport -- What to Do? #47
I'd go buy a newer improved model , ya know one with a diesel engine,4 wheel drive, front end loader and a big whopping heavy duty deck . Then I'd say "honey be a little more careful these repairs are costly" !
   / Wife Destroyed Brand New S240 Sport -- What to Do? #48
I am still having trouble with the name - Sport - for a lawnmower. Obviously I am not a green paint guy but that just says don't wok me too hard.
   / Wife Destroyed Brand New S240 Sport -- What to Do? #49
Buy a new deck and go on with your life. ;)
   / Wife Destroyed Brand New S240 Sport -- What to Do? #50
"Nothing bends like a Deere."
Status
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2005 Sterling Acterra Tender Truck (A53473)
2005 Sterling...
2020 Genie TZ-34120 (A50123)
2020 Genie...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53473)
2021 John Deere...
