Burning Brush
   / Burning Brush #61
I'Let see if a I can get one on clearence.
I'll be using my 3 gal back pack, just dump out the 24d mix and fill with diesel, weed spraying time will be over by then and it usually takes me about 3 gallons to get all the piles going good. The count is up to 10 now and there will be more by the time the season is over.
   / Burning Brush #62
I'm not sure why people are having problems starting fires. Starting fires is easy. Here's an idea: get out the welder near the brush pile and try to weld something up. Guaranteed you'll start a fire.
Haha The only time I have had trouble was with fresh cut trees. In that case I used feed bags and diesel. The sprayer is intriguing because I'm thinking I could burn a thorny mess in place on my barb wire and T post fence line. Pasture on one side and rough lawn on the other.
I've got 3 huge burn piles that won't need more than a match.
   / Burning Brush #63
Mate, we're not having problems. We're discussing alternative ways of doing it.
And yes, using a welder on a tinder dry, no-burning anywhere kind of day is guaranteed to start a bushfire. But I don't have a welder.
   / Burning Brush #64
Use a disc grinder then. I found out that is an excellent way to set grass on fire :)
   / Burning Brush #65
Anyone else use diesel in the sprayer? Sounds interesting.
I just had some concrete work done and that is what the contractor did to pretreat his forms so the forms would release. Spray diesel fuel on them with a garden sprayer.
   / Burning Brush #66
:) Yep, that'll work. In fact that's how a bloke in WA started a bushfire last summer.
I believe that it darn near destroyed a town... several properties & houses before it was finally put out.
   / Burning Brush #67
People doing these activities in dry areas should sprinkle water on their surroundings before and after working, then when finished, sit around with a beer and watch for smoke.
Bruce
   / Burning Brush #68
Bruce
Fire watch 30 min.
   / Burning Brush #69
That is what i am struggling with. If you have to go to all this to start a fire I am wondering how forest fires ever get started. All you need to do is put a match or a lighter up to some paper or dry grass or leaves and you have a fire. I light a brush pile about every month and never had an issue.
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
2023 G Bar K Goose Neck Flat Bed (A53473)
2023 G Bar K Goose...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
