Burning Brush
   / Burning Brush #61
I'Let see if a I can get one on clearence.
I'll be using my 3 gal back pack, just dump out the 24d mix and fill with diesel, weed spraying time will be over by then and it usually takes me about 3 gallons to get all the piles going good. The count is up to 10 now and there will be more by the time the season is over.
   / Burning Brush #62
I'm not sure why people are having problems starting fires. Starting fires is easy. Here's an idea: get out the welder near the brush pile and try to weld something up. Guaranteed you'll start a fire.
Haha The only time I have had trouble was with fresh cut trees. In that case I used feed bags and diesel. The sprayer is intriguing because I'm thinking I could burn a thorny mess in place on my barb wire and T post fence line. Pasture on one side and rough lawn on the other.
I've got 3 huge burn piles that won't need more than a match.
   / Burning Brush #63
Mate, we're not having problems. We're discussing alternative ways of doing it.
And yes, using a welder on a tinder dry, no-burning anywhere kind of day is guaranteed to start a bushfire. But I don't have a welder.
   / Burning Brush #64
Use a disc grinder then. I found out that is an excellent way to set grass on fire :)
   / Burning Brush #65
Anyone else use diesel in the sprayer? Sounds interesting.
I just had some concrete work done and that is what the contractor did to pretreat his forms so the forms would release. Spray diesel fuel on them with a garden sprayer.
   / Burning Brush #66
:) Yep, that'll work. In fact that's how a bloke in WA started a bushfire last summer.
I believe that it darn near destroyed a town... several properties & houses before it was finally put out.
   / Burning Brush #67
People doing these activities in dry areas should sprinkle water on their surroundings before and after working, then when finished, sit around with a beer and watch for smoke.
Bruce
   / Burning Brush #68
Bruce
Fire watch 30 min.
   / Burning Brush #69
That is what i am struggling with. If you have to go to all this to start a fire I am wondering how forest fires ever get started. All you need to do is put a match or a lighter up to some paper or dry grass or leaves and you have a fire. I light a brush pile about every month and never had an issue.
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
