Pettrix
Building a guest house now and the well is about 100 feet from the house. I am planning to run a 100' underground main water line into the guest house and come up under the slab and have the pump controller in the garage. Years later I will build a main house but the question comes into play on how to get water into the main house?
If the well pump controller is inside the garage of the guest house. I can't just run a tee water line from the well area to the main home because the controller in the guest house garage would never know that a pressure drop occurred and so the well pump wouldn't turn on. Am I correct?
I would essentially have to run a line FROM the guest house garage to the main house and both house would run off the one controller in the guest house garage?
Confused. Not sure on how to set this up.
