Best choice for engine heater CK 30 (block, heater hose, magnetic?)
   / Best choice for engine heater CK 30 (block, heater hose, magnetic?) #21
Just curious, what's your nearest Kioti dealer pricing out a block heater for?
   / Best choice for engine heater CK 30 (block, heater hose, magnetic?) #23
Mine still cant find it so I gave up. They say they only have a heater hose one.
   / Best choice for engine heater CK 30 (block, heater hose, magnetic?) #24
I can pm my dealer to you and he can drop ship it to you. It was $68 this past spring.
The closest dealer to me is Moores Corners in New York State. They quoted me $130 for the part. I blanched.....if it is $68 I would put one in two shakes of a lamb's tail.
DOC
   / Best choice for engine heater CK 30 (block, heater hose, magnetic?) #27
   / Best choice for engine heater CK 30 (block, heater hose, magnetic?) #28
jabelding:
Please let me know how the install goes.
Do you use an adhesive on the bushing? I imagine a press fit is difficult to secure without an arbor press.....and really hard to secure on the tractor.
Mine is a CK 30....are the freeze plugs the same size?
DOC
   / Best choice for engine heater CK 30 (block, heater hose, magnetic?) #30
I will let you know how the install goes. I have a Toyota sealant that most people have recommended. Amazon.com: Genuine Toyota Fluid 00295-00103 Formed-in-Place Oil Pan Gasket - 3 oz. Tube: Automotive
It doesn't hold in the bushing the press fit does that, just will seal any small scratches that might leak. I will just tap it in with a long bar and hammer like the others have. Also i want to be sure at full press in depth there is not contact between the bushing and cylinder wall.
I think most of the Kioti engines over 25hp are 32mm freeze plugs.
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A55787)
2014 JLG G12-55A...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2006 Nissan Titan Crew Cab Pickup Truck (A55788)
2006 Nissan Titan...
