Just bought first tractor and got ripped off
   / Just bought first tractor and got ripped off #141
What I'm asking is there a technical reason to grind it flat after welding it? Sheesh. I think I'm typing in English. :confused3:
   / Just bought first tractor and got ripped off #143
Yes there is a technical reason for grinding the weld. I will post the reason on Wednesday,,,,
:confused:
:confused2:
OK, just kidding!! :laughing:
The reason for grinding is it is a cheap way to do a pretty good quality check of the weld.
Many times, it is easy to lay a bead, which only fuses to one side,,, and not the other.
In many cases, the unfused portion of the weld LOOKS great,, but, it will leak.
99% of the time, even a minor smoothing of the weld bead will present the unfused portion of the weld.
   / Just bought first tractor and got ripped off #144
The welded/built up area becomes stiffer than the surrounding metal causing a stress riser. Grinding the repair to blend will give a more gradual stiffness transition and make it less likely to crack right next to the repair. ... A flap disk followed by a needle scaler peening would be ideal.
   / Just bought first tractor and got ripped off #145
Thank you thank you thank you. :thumbsup:
   / Just bought first tractor and got ripped off #148
Oh man, there's hardly a day that goes by where I don't learn something. I'd hate to not learn something every day. That would be boring.
   / Just bought first tractor and got ripped off #149
Do sent matter take pride in your work or don't do it!!!!.
Corrected.
Doesn't matter. Take pride in your work or don't do it!!!!
   / Just bought first tractor and got ripped off #150
Corrected.
That what I wrote and my phone changed it before I looked. The way a person fixes some thing tells a lot about him.
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
Eagle Weathervane (A55853)
Eagle Weathervane...
1000000 (A47477)
1000000 (A47477)
BUSH HOG DISC (A58214)
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
