Broken drawbar... chances a 'pro' welder can fix it
   / Broken drawbar... chances a 'pro' welder can fix it #51
I find it interesting that someone would buy a high dollar, major manufacturer, multi process welder with features he didnt even know how to use, and then recommend to any one else looking at buying a welder to not spend the money on a quality machine. He has even admitted he would like to have even more features on the machine he did purchase, but dont anybody else buy a quality welder, with lots of features, its a waste of money. It gets really old.
Mudd I'm sorry you didn't understand my point. You're not the first, I get typin' on my phone (and type too much, usually) and cuz I can't read the whole thing on the tiny screen I fail to DELETE unnecessary typing. You too, as I can see.....;)
My advice to TBN members is to get a welder of decent quality and just get started, learn along the way. Do this WHILE you have PROJECTS, don't wait until it's all regrets. I advise AGAINST putting a huge barrier in the way (the "go big or go home" theme). I bought my MultiMatic 200 kind of on a lark, but the portability, the versatility, and the multi-process opportunity to learn, have been fantastic. Portability because I weld in several places, not just in one shop. Ability to weld where there's only 120v has been a GREAT option. I could have done better by getting two cheaper machines, where one of them could do AC TIG, so there's that.
If I chose a big 240vMIG like most of the advice here I wouldn't have done a fraction of the projects I've done, and they wouldn't have been done one bit better. Maybe the welds would be 98% instead of 96%, which makes zero difference except for pics on the internet.
I would like to have a shop where I could park a 240vMIG. And an AC TIG. I will someday I suppose, hopefully while I still have projects!
   / Broken drawbar... chances a 'pro' welder can fix it #52
You were doing so good until you got to this paragraph. I used to have a 175 Miller. Traded it for a 250 Miller. No comparison. Much stronger welds.
If all you weld is light metal, the smaller welder is fine. If you weld 1/4" and/or above, the smaller welder will begin to exceed it's capacity and the weld strength will suffer. :)
   / Broken drawbar... chances a 'pro' welder can fix it #53
While I agree with Richard, I have been able to do my projects well enough with my mig, a Hobart Handler 140, biggest 120v machine before input voltage jumps to 240v. Being able to use any 120v receptacles avaliable, even my portable generator, is nice. And I do realize I am often attempting to use my welder beyond its design limits. I often see this in its inability to get good penetration.
   / Broken drawbar... chances a 'pro' welder can fix it #54
With wire feed welders, all it takes is power!;)
   / Broken drawbar... chances a 'pro' welder can fix it #55
Here's what a 120-volt Mig welder can do.
   / Broken drawbar... chances a 'pro' welder can fix it #56
I knew I'd get dinged over my comments. :)
Let me add,,,,, if you are using a light welder on heavy projects the experience and patience of the operator become paramount. A larger welder will better make up for operator inexperience. :)
I saw an Iraqi man weld with a gas engine powered generator using a piece of cardboard with a slit cut in it for a helmet. His work was respectable. But I wouldn't suggest everyone go buy an old piece of crap generator. :)
   / Broken drawbar... chances a 'pro' welder can fix it #57
LOL.. Ding you Richard, ding you! *grin* not cuttin on you at all... respect your input.
We are getting a little off topic, but still relivent to the issue of welding, just not the broken draw bar. I think we all agree on that, a DC stick welder running 7018 is the trick there.
As to a small mig and running it above its ability, heating the material with a torch can help the mig get better penetration, as the base metal is that much closer to the melting point.
   / Broken drawbar... chances a 'pro' welder can fix it #58
And that's the trick the novice will know nothing about. :)
   / Broken drawbar... chances a 'pro' welder can fix it #59
Exactly why I posted it... now they do! *grin*
You, and others, make some good points...
I'm stuck in the small boat... I make do with my lil 27hp tractor, and 120v mig... where there's a will, there's a way, and just like eating an elephant, it's all just one bite at a time.
   / Broken drawbar... chances a 'pro' welder can fix it #60
Greg, I have no idea how many welding rods I burned up using a Tombstone Lincoln for a cutting torch because I couldn't afford to buy one.
"Use what ya got and be proud". :cool:
PALLET OF MISC PUMPS (A51248)
PALLET OF MISC...
2025 INDUSTRIAS AMERICA 7014 70"X14' HYD DUMP TRL (A51247)
2025 INDUSTRIAS...
UNUSED INDUSTRIAS AMERICA 12F HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A53473)
2018 Link-Belt LBX...
Broce KR350 (A50123)
