Steering Brakes,,, A Necessity,, Or A Nicety?? (41HP, 3000 Lb Tractor)
   / Steering Brakes,,, A Necessity,, Or A Nicety?? (41HP, 3000 Lb Tractor) #41
I use the crap out of my steering brakes on both 4wd tractors that have them. Wish the third did. :)
   / Steering Brakes,,, A Necessity,, Or A Nicety?? (41HP, 3000 Lb Tractor) #42
Thanks for the replies!!:thumbsup:
The tractor I looked at is a JD 4105,,
it is like the entry level CUT,, bare bones tractor.
No cruise control, no steering brakes,,
two speed hydro,
rather than three,,, etc,,,
I don't think anyone has steering brakes with a hydrostatic trans. I may be wrong, never had a hydro tractor (yet):thumbsup: Thought I remember reading something about needing 2 right feet:confused3:
   / Steering Brakes,,, A Necessity,, Or A Nicety?? (41HP, 3000 Lb Tractor) #43
My late 70's IH 2500b was a 50PTO HP 8000# cabbed 2wd HST tractor loader and it had split brakes. Both brake pedals were on the right foot as was a foot throttle and a differential lock behind you're right heel. The two directional pedals were under your left foot.
   / Steering Brakes,,, A Necessity,, Or A Nicety?? (41HP, 3000 Lb Tractor) #44
Almost all hydro tractors have steering brakes, only a few don't. Now as to how easy they are to use is another matter. Many are not that easy to use without contortions or gymnastics. Mine on my Kioti DK35se are extremely easy to use and are very effective. They are on the left side to be activated by your left foot while your right foot mashes on a hydro pedal.
   / Steering Brakes,,, A Necessity,, Or A Nicety?? (41HP, 3000 Lb Tractor) #45
I have never used my breaks to steer, I have them locked to be one. Breaks are on the left foot, deff lock is on left heel and two directional petals on the right foot.
   / Steering Brakes,,, A Necessity,, Or A Nicety?? (41HP, 3000 Lb Tractor) #46
Very cool. I've never saw HST pedals on the left!!! :)8
   / Steering Brakes,,, A Necessity,, Or A Nicety?? (41HP, 3000 Lb Tractor) #47
You my friend have the ideal setup and don't even know it.....
   / Steering Brakes,,, A Necessity,, Or A Nicety?? (41HP, 3000 Lb Tractor) #48
But they are there if you need them and they would be convenient to use too. Pushing snow/ice on a parking lot that slopes is one good use for a steering brake. Give it a little right or left "rudder" and "tack into the wind". Working dirt up against a building is another good use for them. You can also use one to slow down a spinning wheel so the other wheel will take off and pull you out of a mud hole is. It can be used to "twist" you out of a stuck situation also and get your nose pointed downhill. It works as good or better than the differential lock, and you can use it while spinning a tire, you can also switch back and forth to "wiggle" out of a stuck situation, As well as just use one to make a sharper turn to miss an obstruction. Lots and lots of reason to use split brakes. Another arrow in your quiver. Try them some time and get good at using them, and you will like 'em too.:)
   / Steering Brakes,,, A Necessity,, Or A Nicety?? (41HP, 3000 Lb Tractor) #49
But they are there if you need them and they would be convenient to use too. Pushing snow/ice on a parking lot that slopes is one good use for a steering brake. Give it a little right or left "rudder" and "tack into the wind". Working dirt up against a building is another good use for them. You can also use on to slow down a spinning wheel so the other wheel will take off and pull you out of a mud hole is a good application also. It can be used to "twist" you out of a stuck situation also and get your nose pointed downhill. It works as good or better than the differential lock, and you can use it while spinning a tire, you can also switch back and forth to "wiggle" out of a stuck situation, As well as just use one to make a sharper turn to miss and obstruction. Lots and lots of reason to use split brakes. Another arrow in your quiver. Try them some time and get good at using them, and you will like 'em too.:)
Well stated James. I obviously lack your tact. :)
   / Steering Brakes,,, A Necessity,, Or A Nicety?? (41HP, 3000 Lb Tractor) #50
2015 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER TRUCK (A54313)
2015 VOLVO VNL64T...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2008 GMC C5 (A53422)
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
