Looking for advice on which direction to go
   / Looking for advice on which direction to go #11
If I was buying a new tractor just for snow removal this would be some of my wants.
1) plenty of hp. At least 5 pto hp per foot of blower.
2) a cab. A good one with wipers and lights
3) good heat in the cab. Not some propane buddy heater or electric heater real heater core heat.
4) what else can I use the tractor for in the future, like mowing if you change your mind of tilling a garden. Or maybe a blade in front blower on back.
5) storage. Can I fit it in my garage or where ever you plan on keeping it or working on it.
6) is there a dealer support and parts available for what I bye. This one might be more at the top of my list.
   / Looking for advice on which direction to go #12
That Steiner for $8000 sounds like a good deal. I think you might even enjoy mowing the grass with that if you found a front deck for it. I love front mounted mowing decks.
   / Looking for advice on which direction to go #13
That was not at all on my radar, but I am very open to alternatives. Why do you like the rear-PTO option? I just can't imagine driving backwards all the time, but maybe it's easier than I think(?) or the results outweigh the disadvantages, or...?
Honestly I had categorically ruled out a rear-PTO solution, but also recognize that another perspective can be superior to mine. I know, I know, hard to believe, but true.
Thanks,
If you invest in a simple cabbed mule with heater or not you can simply put a very firm pillow behind you to support you until you become more comfortable with how to sit in the seat.
Some of the members invest in swivel seat and some mules have that as an option but that is in the larger engine frame size mules to allow for easier crop harvesting with towed machinery.
The thing is that you can turn sideways in the seat and push the reverse pedal to move and the snow caster is nothing more than a boat anchor as long as you have rear chains and the rear tires loaded with windshield washer fluid.
Your going to be running that engine at the Rear PTO implement speed and at 540 revolutions per minute and on the first pass your going to be taking a full cut at a slow speed of travel and you can take half cuts on the next passes.
You can buy a wider rear snow caster in the next horsepower size rating for a smaller mule and just travel a bit slower and make fewer passes but still eliminate the plowed snow bank mess that will trap snow in plow cut.
As long as your three point hitch has the hydraulic power to lift it it will work for you.
If you buy a front mount snow caster the Mid PTO is used wherein the power is transmitted to either a gearbox or a reversing chain system to power the front mount snow caster.
The front mounts require an under frame mounting system and they are vicious when they bite because you forget that frame is sticking out someplace in a dark garage.
A smaller mule will work with a wider snow caster as long as it is operated properly and not abused.
You have to understand that the current two stage snow casters are designed mostly for powder snows and
the open auger system is not your friend. you have to keep the impeller filled to make the most use of the number of impeller paddles it has meaning the slower you travel the faster the snow caster will allow the impeller to throw it.
The gap between the impeller paddles and the impeller drum is the worst part because the friction from the impeller will melt the snow and cause it to become less efficient and use more power with a front mount and a rear mount unit BUT clarence's impeller kit solves that by sweeping out all the snow and ice chunks.
Many of the members have small sub compact mules with front loaders and rear mount snow casters and many also have wider rear mount snow casters using the sub compact mules.
Look at it this way.
Any rear mount snow caster has fewer parts and a direct drive impeller system from the 540 RPM PTO through the gearbox.
The limiting factors are/is/will be available power, money, debt service BUT having a wider snow caster lends itself to making wider passes at slower speeds where the impeller is rotating at its maximum speed clearing the snow that is fed to it BUT the open cross augers do not cut the snow up the impeller does that and it makes the impellers job that much harder as it has to shear the snow being pushed into it to cast it away.
no one makes a single stage snow caster with a solid cross auger UNLESS you are will to invest in an RTV/UTV/quad bike motorized snow caster from Finland-they do move a lot of snow. you would need a quick attach kit for a front loader for it to work but the weight will not let you lift it very high and you would not want to do that anyway as the loader could not handle it.
A smaller mule with a loader and snow caster is a good combination to move snow and remove it. many of the members have them and use them on monster driveways and many that are on inclines/hills and they are well equipped with loader rear tires and snow chains for the work.
you have to do a lot of decision making with a decision tree and or a reverse decision tree if you want to be clinical about it to arrive at an algebraic solution to this.
Remember if you skimp on quality it will bite you in the posterior and you will not be happy changing shear pins in a snow storm and not having a magnet light and forgetting to use a tarp to lay on while working on it is the first mistake you will make.
Remember bringing a knife to a gun fight does not work unless you are good at throwing long distance and your opponent only needs one chance to do business.
its better to have more a mule with more power and a loader and a wider snow caster. You will not be able to dig up frozen snow banks with a loader or a plow
If you buy a snow caster with the extended chute option it gets the snow above the canopy or cab and reduces the snow dust to a minimum.
In one of my threads I went through this completely and much greater detail for a member and I am sure its still on the snow removal or attachments section.
ASK YOUR NEIGHBORs about what they use for snow as you will be the one stuck with the task and you know how much time and money you have to work with.
Never mind the horsepower per foot of width suggestions!!!!!!!, as the gearbox rating for the snow caster is what is doing the work for you. The poorly designed open auger method is a curse in snow of any depth as the snow is pushed forward as you back up or drive forward with a snow caster of either type.
A smaller 4 wheel drive mule will take longer with BOTH A rear mount AND a FRONT mount snow caster but you can use a loader the year round too and a mule without a loader has a very low resale and trade value!!!!!!!!!!!!!!!!!! If you have snow and ice a 4 wheel mule will get stuck and very stuck and you need chains and loader rear tires and avoid calcium chloride as it will eat the tire rims as most mules have tubeless tires now.
   / Looking for advice on which direction to go #14
I just returned and found your post. There are several members with BX 1860's/BX2360's that have rear mount
snow casters and they have posted pictures of them working. The TBN member that lives in Newfoundland
has posted several videos of his snow clearing after storms/snowfall using a link to you tube from the snow removal page and you can watch as he works. His mule has a front end loader and no chains with turf tires and I do not believe his rear tires are loaded as he spins a lot with it so its a safe bet it has no ballast in the rear tires. I put up with that for one winter and then I bought a tire filling valve from gemplers and simply filled the rears with gallon bottles of windshield washer fluid until I had 6 or 7 gallons in each rear tire. I have two suitcase weights (82 pounds) and snow chains and sometimes that is not enough due to the LA115 being 2 wheel drive.
I believe his rear mount snow caster is an RAD hiding under Kubota paint uses a BX2360? to clear out his drive and parking space and the neighbors as well with good results.
The JD front mount I have is belt driven and a pain in the *** to repair and the JD belts are too expensive($120.00USD) and do not last. I have size A116 belt spares for it when the time comes to replace the one that is on there now.
My unit would be so much better off with a belt driven gear system that its not funny. The original IHC Cub Cadet I had while growing up had 12 horse power Briggs and Stratton and was a single stage snow caster and there was no pile of snow it did not remove. the single stage snow caster was belt driven to a right angle bevel gear drive system that rotated a drive shaft that came off the gear box to a chain drive outside the snow blower frame for the solid cross augers rotation and all that thing did was work and barely grunted when it met with snow.
   / Looking for advice on which direction to go #15
Heck, a rear snow caster with a camera system (in a cabbed tractor) makes life good ( at an affordable budget).
Cabbed for comfort, camera to save the neck .
FRT mount casters are a 'make do to meet market' and not all that great IMHO, tractors are designed to use the rear PTO.
Heck I installed a camera system and honestly I simply sit 'side saddle' and blow going backwards, after all It is all of 20-30 mins every snow event, won't kill me!.
No final decision yet, but I am currently inclined to a CUT with rear 3pt blower.
I've located a Kubota L275 4WD. Yes, it's 35 years old but has under 1000 hours and would seem to have been very well maintained, and has new AG tires all round.
Based on the dimensions and power I'm thinking that a 64" blower would be a good match, and that would be a good fit for my site, I believe.
KUBOTA L275
One further question. When you talk about a "mule" I'm guessing, from context, that refers to s 2WD tractor?
   / Looking for advice on which direction to go #17
I also recommend the 3 point snow blower, front loader, a cab and rear tire chains (2 link not 4 link).
For the past 12 years I've been using that combination, with my Kubota B7800.
I have a 530' and 300' driveway along with two large turn around areas, takes me 1.5 -2 hours, on every storm.
I'm not to sure you really need a heated cab. I dress for the cold incase I need to get out in the elements to change the occasional broken shear pin.
I'm 66 and find it often gets too warm in my unheated cab due to the heat generated by the tractor's engine and transmission. Sometimes the inside of the windshield fogs up, but is easily wiped clear. I'd recommend holding off on the heater, you can always ad it later if you think you need to.
I'm not sure if it's already been mentioned, but IMHO a hydrostatic transmission should also be part of this combination.
An engine block heater would be good too.
   / Looking for advice on which direction to go #18
KUBOTA L275
Nope; A mule is either a 2 wheel tractor or a four wheel rear drive axle/or a 4 wheel drive tractor.
The L275 is an excellent Kubota Import directly from Japan.
Just check to be sure which direction the PTO rotates before you hand over any money as you
may need a reversing gearbox to run a rear mount snowcaster.
If it spins to the right you will need a reversing gearbox.
   / Looking for advice on which direction to go #19
KUBOTA L275
Yep 60'' or 64'' would be a good match, tractor looks in great shape , you will be impressed at what a little beast like that can do with a quality blower and still under your budget
Thanks for the tip! I haven't done anything with 3pts/PTOs for decades and would certainly have missed that "little" detail...
White 5100 / 6900 Planter (A59814)
White 5100 / 6900...
Woods 1800 Batwing Mower (A59814)
Woods 1800 Batwing...
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
