NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've been wanting one of these for years as an option to my fueling devices, but at $100 plus they were always to rich for my wallet.
Now they are $99 AND with coupon code 252522 it brings them down to $80 with FREE SHIPPING, and my wallet said OK.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #2
Thanks for posting that... I've been thinking about getting one and that was the push I needed...
Thanks again,
SR
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #3
I bought a couple of these a few years ago. Save your money, they are garbage. The hoses and nozzle will break in short order. Try getting parts. Again I say GARBAGE!!!!!
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #4
Others on line, like them, so??
SR
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #5
Did you use them with diesel or gas?
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #6
Used them with premium gas. Maybe they've upgraded the hoses and nozzles since I bought mine.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #7
I second the nozzles breaking. Well.. leaking.. you have to follow the instructions of doing like 6 pumps max and letting it gravity feed... if it's on the ground and you try to gas a mower up and keep pumping on the nozzle I suspect the vacuum is what breaks something inside.. the safety is annoying and hard to operate with one hand.. (I.e. if you're holding a cap that you can't set anywhere, it becomes abit cumbersome..)
Did not have the hose nor the valves leak but I rarely use mine now.
I much rather use traditional 5 gallon Jerry cans and for smaller things I use a 1 gallon.. you won't spill, light enough to hold..
The issue is, the tank is too small for its intended purpose. I.e. lift it up and let it flow, something like a jetski or side by side can take the whole juel tank in a sitting...
Not to mention the hose is on the short side to be mounted/lifted ...
I paid around 120$ canadian for mine on sale, and if I DO use it it's because I need to store a lot of fuel for a week or two, then pour it into 5gallon Jerry cans and 1-2gallon ones and use those daily.. this is just a tank to refill my tanks..
It's too cumbersome and heavy to bring somewhere out in the field or behind the garage ...
If you do buy one, be gentle on the gun, and be prepared to lift it up or store it somewhere, where your equipment can drive up to it..
Having it on the ground and pumping up takes longer than tipping over 3 Jerry cans..
Basically if you want a big tank, go bigger and mount it on a skid with a 12v pump.. something in the 30gallon range or higher (remember gas becomes stale so figure out the amount of gallons you need that you will use up in 1 month to 1.5months MAX). If the demand is smaller than 25 gallons a month, 5 Jerry cans would be more than enough.
(A skid mounted tank is great because it could be put in a truck bed or mounted on a trailer, etc)
(I know most people will say the skid is going to cost significantly more, but there's a good chance you can find used semi truck tanks made of stainless or alum for cheap, and a 12v pump (or even a manual hand crank pump) will cost you around 200.)
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #8
I have bigger tanks, from 70 gallons on up, I also have several pumps including a 12V pump...
This one will be for E0 gas and I can fill what I need filled, right off the back of my pu, once I fill a few things, it will be light enough to lift off the pu bed.
Anyway, we will see how it works out...
SR
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #9
Like Greenland South said.....save your money. They are junk. Tried two of them. After a season the handles will leak out every seam and they loose prime and won't pump. And the hose gets as hard as rock in the cold.
And gas seams to destroy any rubber seal that is in them.
<snip>
<snip>
My concept for it's use is primarily refilling tractors w/FEL's
Fill it up in the pickup bed, roll , put it in the bucket, store it. Put it back in the bucket, lift and siphon into the tractor.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #11
Can anybody click on the link the OP posted and get to it? I have been getting lots of links redirected to some vigilink page. Some work and some don't. I have noticed all links to Agri Supply get redirected. Have they banned all but sponsored links?
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #12
Can anybody click on the link the OP posted and get to it?...
Yes, no problem here... I run Firefox with Ad Blocker Plus, Ublocker and NOScript. No ads and no problems...
Good news is you are generating money for TBN... me, not so much.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #13
I've mentioned this on other related posts. I've tried most of the cheaper' super siphons' and 'gas gizmos' and whatever and finally give up and bought a 12volt Fill Rite pump Fill-Rite Home Page - FillRite
to do the job. I mounted the pump to a bench in my gas shed and installed a flexible pick up hose to the bottom to insert into 5 gallon cans of either gas or diesel. I don't go thru a lot of fuel in my toys as compared to a commercial operation and it's easy to bring home what's needed in 5 gal cans. Good for lawn equipment , tractor, ATV and snowmobiles. I recently bought another small pump called 'The Pocket Pump". Pocket Pump.ca for $30.00 and am very happy with it so far. Runs on 2 D battery's and good for smaller fill-ups like lawn mower and chain saws. Almost no spill.
Al
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #14
I'd say elevation for gravity feed is key with these. I use a cheap 3 or 4 sheave manual rope hoist in my garage to lift mine.
The nozzle is definitely consumer grade. Mine has stood up for a few years of occasional use, but I'm the only one using it, and am pretty careful. I use it to store generator fuel, and for vehicle emergency fuel. I only put E0 in it. With the can elevated, I only use the handle pump to get things started to flow.
This company sells the pump handles in separate hose/can adapter kits I think; that would be one way to get a replacement handle off-the-shelf if needed in a hurry.
Plan on replacing the hose, unless they've really stepped up their game (doubt it, at the price-point). Mine was a hard plastic hose (likely to stand up to E15 etc....) and was unsuitable for my climate - I don't remember the hose leaking, but it kinked so bad that the flow was reduced quite a bit - I replaced mine with a decent commercial bulk hose. Shut-off valves seem decent, knock-wood.....
I wouldn't expect the nozzle to survive with a landscaping/maintenance crew, but if you are careful and can elevate the unit most of the time, then you may find it OK for light personal use.
One thing I can say about the nozzle - if I was away from home and my wife needed to fuel something ASAP, I'd sooner her use this nozzle than a regular gas can. The one time years ago she tried refueling something on her own (outdoor maintenance/chores has always been my domain) from a can, she managed to spill gas all over the place - didn't question the event too closely at the time (she felt bad enough), but I suspect she just didn't have the regular can nozzle tightened down well enough.
Rgds, D.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #15
I run ad blocker on firefox but not the other stuff. Guess I will try them.
Just tried the link with chrome on my cell and same redirect to vigilink occurred.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #16
It is offered on Amazon (at a substantially higher price) but there are hundreds of reviews. They read about like this thread - half thing it's great, and half think it's junk.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #17
I bought the 28 gal one at an auction sale for 60.00. Best money I ever spent. But on mine it had a pump in the end standing up and I replaced that with a 12 volt fill right pump. I have a 1 inch valve at the bottom in the front which I plugged. Some day I am going to mount the pump on the wall and plug the 2 inch hole in the tank, then run th hose from this 1 inch valve at the bottom to the wall and use quick disconnects si I can disconnect the bottom line pick the tank up with my forks and take it to fill it
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #18
I ordered one from the original link and it came right away...
Looks like it will be fine, we will see how long it holds up.
SR
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #19
I've been trying to figure out a good way to store at least 2 fill-ups, or about 20 gallons of fuel for the tractor. I've yet to find a sub 60ish gallon tank with anything other than mediocre reviews.
   / NT Flo n' Go Duramax Gas Caddy 14-Gallon, $80 #20
I like the simplicity, durability, and reliability of these: VP Racing 2 Pack Square Red 5 Gallon Race Gas Alcohol Can Fuel Water Jug IMCA
Five gallons is still manageable for me. Fourteen isn't. Then again, I always fuel outdoors.
For 2-cycle stuff, I have a couple of these: https://www.walmart.com/ip/No-Spill-LLC1415No-Spill-Gas-Can-1.25-GAL-GAS-CAN/38473987 I switch off with them, so I haven't run dry.
And I keep a 2 gallon can my wife can handle. Every month or so, I empty what's left into our daily drivers and refill the cans (except the 2 cycle, of course). I have a five gallon diesel unvented (CARB compliant) plastic jug with the old flex hose (non-CARB compliant) that I use for my tractor, which is my only diesel-powered machine. I get down near the empty mark on the gauge and drive up by the shop. Stick the hose in the filler, lay the can on the hood, and go do something else for a few minutes. Can will be nearly empty when I return (7 gallon tank) and I just tilt it up to drain the last of it into the tank. Next time I get gas, I get diesel too.
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
CAT930K (A58214)
CAT930K (A58214)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 CATERPILLAR 299D3 XE SKID STEER (A60429)
2022 CATERPILLAR...
