F250 motor swap, 7.3 diesel
   / F250 motor swap, 7.3 diesel
Got the injectors in, the fuel lines to the heads on, the valve covers and gaskets on, the oil cooler on, the water pump on, and was going to get the turbo mounted... but I can't find the d@mn bolts that hold the turbo pedestal to the block ANYWHERE. And the bolts from the motor I took out are too short, already checked that, stole a few others I couldn't find. There's bound to be a coffee can in the barn somewhere full of bolts in the place I left them, thinking "I'll leave them here so I can find them easy when I need them..."
   / F250 motor swap, 7.3 diesel #132
Dykem? Elaborate please... a quick Google search didn't readily reveal how I could use it, I'm open to suggestions and ideas!
I think that was what it was called. It is a thin fluid that is colored red or something and you use it to find cracks in castings or metal parts. You spread it on the part where you think there may be a crack, then wipe it off the surface, and some of it will remain in any crack and highlight it. It can show cracks that you cannot see otherwise. I might have the name wrong...
   / F250 motor swap, 7.3 diesel #133
I hate when I do that..... The older I get the more important it becomes to finish projects quickly. Stuff just disappears.... :)
Mystery solved... I never had the bolts! Got to thinking about it earlier today, and remembered that the turbo pedestal was separate from the block, disassembled when I had pulled the motor over 3 years ago. Sent my buddy a text, he looked, and sure enough, right where I left them, in a plastic bag, neatly labeled "turbo pedestal to block bolts, Y2K 7.3 PSD".
So... turbo in place, fuel bowl drain line in place, and exhaust manifold drilled and tapped for EGT probe.
Getting closer...
   / F250 motor swap, 7.3 diesel #135
I was going to suggest looking in cylinder number 3. That's where I usually find stuff!!!! Especially when you hit the starter.
   / F250 motor swap, 7.3 diesel #137
Glad to hear your making progress Greg!
   / F250 motor swap, 7.3 diesel #138
I put a shreider valve in the coolant line that comes off the top of the degas bottle. Pressurized it to 15lbs I think it was. Had 6 cracked cups.
Works... if installed, cooling system intact. My motor is out, on a stand... for now. I'm gonna take my chances, injectors in now, buttoning things up to get it back in the truck asap.
2022 LOAD TRAIL INC GP0240122 LOT IDENTIFIER 251 (A53084)
2022 LOAD TRAIL...
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51248)
KNOW BEFORE YOU...
UNUSED FUTURE 1R RIPPER (A51248)
UNUSED FUTURE 1R...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A51248)
UNUSED WOLVERINE...
