Steave
- Joined
- Mar 1, 2012
- Messages
- 846
- Location
- Taylorsville, GA
- Tractor
- 3000 Ford 66' 260A International Backhoe, Belarus 250AS
I'm not sure why he needs to take it apart. There is no indication that it isn't functioning properly. As mentioned, if the tractor is bogging down it is the chipper/flywheel, not the slip clutch. The clutch has nothing to do with the load of running the implement, only shock loads. So unless the OP is worried that it isn't slipping then there is no need to take it apart.
The indication that it not working properly is that it's bogging the tractor down on start up. If it's working properly it should allow some slippage until the heavy flywheel is up to speed. It will heat up while doing this is the reason for the heat sink fins. That's my take on how it works and I'm only wrong every now and then so watch out this maybe one of those times.
