GC1720 wheel spacers
   / GC1720 wheel spacers #11
I went and grabbed a piece of 2x4 and took some pictures and measurements. Here is what I came up with, if I did this wrong let me know.
Greetings Chad,
Well, what you are showing maybe could work for measuring - but it isn't what I was thinking of. More importantly - you seem to have your rear deck wheels set much higher than mine and maybe its just the pictures - but your rear deck wheel seems to have less space to the tire than does mine.
As an example - my rear deck wheel on the right side is about 2 inches further out than my tire and it is set forward more. Now granted if I raise the deck up to its fullest height - that effects things some.
But the idea of the deck wheels is to have them set for just above the height of grass height you want because the deck is a suspension deck. Then you raise and lower your deck for fine tuning. It almost looks like your deck wheels are set so lowering the deck would cut it down to maybe an inch high. I don't know if turf tires are narrower than yours - but it seems like I have more space from the camera angle you have. Essentially - you want to be able to raise and lower your deck with your hydraulics - so that the roller wheels or brackets don't hit the rear tires.. then you measure outside the side of the tire to see how far out you'd still have clearance. When my deck is all the way down I'd have more clearance than when I'd pull it all the way up. And because the deck wheel sticks out further than everything else - I wouldn't want the deck wheel adjusted to the very very top.
Its raining now - but I'll try to take some pictures tomorrow.
I was thinking of having a 1 x running 90 degrees different from your's (in other words going in the same direction as your 2 rear deck wheels. Then you can see how close
   / GC1720 wheel spacers #12
Mr. Chad -- I basically agree with AxleHub. Let me add a couple of opinions. (My machines similar to yours are Kubota, not Massey but the principles are the same.)
1) Fluid in the tires is almost always rear only and is for traction, not helping on steeper ground. Wheels spacers or anything you can do to get a wider tread in back is a huge improvement in avoiding tipping over or getting close enough to tipping that it becomes an issue. Fluid in the tires may help a small amount but very small, I say negligible.
2) On one B2150 tractor I use 6" spacers of the Bora brand and find them to be excellent in quality and in the company having all the little subtle things figured out for compatibility and fit. With an added foot of tire spacing my B2150 is daylight/dark safer to use with a small bush hog on steeper ground -- actually feasible versus NOT feasible ! However, I cannot use my midmountmower at all with the spacers -- tires will not clear the deck.
3) I'm using very large turf tires and it looks from the picts that you are using ag tires or maybe industrial tread. You probably will have more space than I do because of tire type if everything else was equal. Your worst-case will be with the deck raised. As was suggested, run a 1" board or any handy straight object across the back of your rear tires , between the rear tires and the deck wheels. With that board in place, does it clear everything or are the mower wheels too far forward to even get the board in there ? If the board clears, even while you run the mower deck up to the highest point, you'll be OK running the rear tires out as far as you like. In other words if the mower wheels are too far forward, then at some point you'd have a conflict trying to widen the rear tractor tires. I think you can see that but obvious things are often hard to describe in English.
Again -- if you want to be/feel more stable on steep slopes then move the rear wheels out as far as you can. As Axle Hub said, you don't want tires and deck wheels colliding AT ALL but on the other hand you really don't need a whole lot of spacing either.
Greetings Chad,
I'm thinking my industrial tires are bigger than your turf tires. I tried to put a 2x4 next to my rear tire and it will hit the tire on my mower. I took some more pictures. Let me know if this is wrong and I'll try again lol
And can you help me set my mower deck up? My dealer told me I could adjust my deck wheels up or down for my height and then lower my deck the whole way to the ground and it would basically become a floating deck. Or he said I could "fine tune" it with the adjustment knob and then lower it and it would become a suspended mowing deck.
Is one way better than the other? Or what's the correct way?
How tall should the lawn be after cutting?
Sorry I'm knew to all this. As a kid we just cut it short lol.
   / GC1720 wheel spacers #14
Yes I'll get numerouspictures tomorrow so you can compare. We all gotta learn lol.
One thing for me is I tend to adjust my deck for about 2.75 inch grass. When you start cutting shorter than that it's often hard to keep the weeds away because they grow faster and can handle wind and dryness better than the grass can. And because of mulching. . I don't use fertilizers at all so I have lots of worms near the surface. But the herbicides and a little pesticides help I grow we and thick it I don't need to cut every three days like all the neighbors either lol.
So do you just set the bottom of your mowing deck 2.75" off the ground? Or is it not as simple as that?
   / GC1720 wheel spacers #16
If you have the deck set low enough that it rides on the deck wheels, the wheels will wear more quickly, and they're expensive from Massey. I now keep my grass a bit taller than I used to, for reasons mentioned above, but use the deck height control to keep the wheels --mostly-- just off the ground, i.e., they touch once in a while only. That seems to be working better for me. I suppose my grass height is now around 2-1/2" or perhaps a bit more; I used to keep it closer to 1-1/2". (Keep in mind you can also change the height of the deck wheels as well.)
   / GC1720 wheel spacers #17
Greetings Chad,
The Massey mowing decks are really not designed to have the decks rolling on the ground - they are designed to be suspended from the tractor. On the 2315 mulching deck - the purpose of the rollers (most of them hidden) and the 4 exterior wheels - is to deal with ground irregularity (small knolls in the lawn or washboarding or hole or rut strikes by the tractor wheels. In addition, if you are sidehill cutting with the wheels riding on the ground - you'll get more of an angular cut because the deck wheels will rest more on one side of the ground compared to the other.
And as Irving mentioned - the rollers aren't too bad for price - but the deck wheels are a surprise unless you can find a compatible.
A final issue with the wheels riding on the ground is to remember that the 2315 deck weighs 220 lbs. And if the ground is wet - your cut would be shorter as the wheels would sink in more (much greater weight per sq. inch on deck wheels compared to the tractor's tires).
And I'll just mention that I don't know that your tires are bigger than mine - it could be your deck is adjusted "further back" than mine is (front adjustable U shaped mounting point bracket). By the way - that's one of the reasons why the deck pto shaft has a varying length to it. So the way I do it is to set the deck wheels for a distance to ground that would be the "shortest height" I'd ever consider ever cut any lawn surface (leaf chopping in late fall) - then I set deck drop to either 1. my slope cutting height or 2. flat lawn cutting).
Here are some pictures of my deck showing the deck resting on the wheels on the ground and at full up position. I also took shots showing where my pins are set on the wheel brackets - and the gaps to be considered when choosing spacers. All photos are labelled for direction and position.
AxleHub
Axlehub,
Could you measure how wide your turf tires are? Cause I think my R4s might be a tad wider. But I'll measure mine to and we can see
Also how far forward on the U shape bracket do you have you mower set?
I'm at work all weekend, but I'll adjust my deck Monday and take new pictures and measurements to compare.
Thanks
   / GC1720 wheel spacers #19
Chad,
The rear turf tires on my GC1715 are 12 inches wide and 24 inches as a diameter - they are not worn. (yes, 24 inches - I measured 3 times even though the tire sidewall says 26 x 12 LOL
AS far as the u shaped front attachment bracket for the deck - I have 1 inch of threads exposed.
P.S. Also see page 32 of your MF 2315 operator manual for a different finish cutting adjustment using "floating method" instead of "suspension method".
AxleHub
AxleHub,
My industrial tires measure 25.5" x 12" tread width to closer to 13" to outer sidewall.
My mower deck has the same 1" of threads showing in the u shape bolt in the front.
As far as setting up the mower deck, I'm not sure if I got the mower deck manual. I'll have to double check. But I set my deck wheels up to the diagram to give me a cut height of 2.6"
So what number on my turn knob should I use? The one that barely lets the wheels touch the ground in assuming?
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2012 SANY SRC 840 4x4x4 40 Ton Rough Terrain Crane (A60460)
2012 SANY SRC 840...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59905)
2018 VOLVO VNL...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
2006 Freightliner Auger Truck (A56438)
2006 Freightliner...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
