Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #751
Just went back into the settings on mine and found it still set to 30 minutes. I reset it to no time out and will have to see if it sticks this time. Maybe I will get the finicky out of this thang!
Struggling to get my chromecast back working. I reset the chromecast to the Mobley and it is seeing the network and displaying rotating images but can't get anything else to see that now. EDIT: Had to do a factory reset on my Chromecast dongle and set it up from scratch to get it back working on the new network.
How to change Chromecast WiFi network? - All About Chromecast
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #752
More feedback.
My PC trying to wifi to the GL-AR150.... "Can't connect to this network."
I tried my android phone, then an ipad....both say...'incorrect password'.
I completely reset the GL-AR150 router and redid everything, and it changed absolutely nothing.
For reasons I don't understand, trying to wifi to this router it cannot interrupt the password I give it.
At a lost.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #753
sodamo...need your advice on the GL-AR150.
I have it hooked to the Mobley. I can plug into the lan port to my laptop and I get the internet thru Mobley. router is usb to Mobley. BUT, I cannot go to the router via wifi. I see it trying to connect, network light blinks on the trys, but ends with "Can't connect to this network."
SO...it works via cable, but not the wifi.
Under internet settings....cable is DHCP, 3G is the same as photo you posted, if I try to do anything under repeater, it says can not update wan.
Lost as to what to try next.
I also set DNS on router to 8.8.8.8 and 8.8.4.4.
Ar150 not accessible from where I am, but ar300 same settings:
Hope it helps
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #754
Found the problem. When first logging into Mobley you provide the password. When setting up the wifi...you have got to repeat it. In the password field it says 'Leave blank to keep un' ..... and I took that truncated message as meaning to leave blank to keep unchanged. I guess not. I repeated the password in that setting...then wifi worked.
Speed test shows very little difference between being logged direct to Mobley or on the GL-AR150.
Good to go.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #755
Hey, that's good news
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #756
UPDATE for anyone interested.
This morning, the Mobley was working fine....then boom, no signal. I had to run to town, did so, some 3+ hours later, I checked it still no signal. I did a chat session with at&t.
After going thru many different motions including a 'master' reset of the device....that corrected it. Seems I hit the 22GB limit, and per the tech he noted that he saw this on the account. When I hit it, they effecting locked the Mobley (probably in error) and this 'master' reset was need.
I said on forums, many using the Mobley had not been throttled....his reply.... "yeah its just a way to kinda conserve usage on the network, to be honest it doesnt happen too often but we do see it sometimes." I was the sometimes.
The good news, I got back on the Mobley, checked speeds, they are the same as before. So the 22GB was hit, but they did not throttle, but they did something that required the Mobley to have this master reset.
That is odd, I have gone over 22 GB every month, well over and never had any issues, well good to know if I do I can just reset.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #758
Received my GL-AR150 router and it has no external antenna or any place to plug one into.
Edit: got it working but password change didn't take.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #759
So how did you "Master Reset" the Mobley?
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #760
The GL-AR150 come in 2 flavors with or without external antenna, item description/pic should have shown appropriate. W/0 is a dollar or 2 cheaper.
Once connected, follow the instructions to access and set up similar to the screens I posted earlier. Really easy if you don't over think it.
John Deere 1775 NT Exact Emerge 24 Row Corn Planter (A52349)
John Deere 1775 NT...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
New 4-235/80R16 Montreal Trailer Tires (A50774)
New 4-235/80R16...
2013 Hyundai Sonata Sedan (A50324)
2013 Hyundai...
2010 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2010 Ford F-150...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52748)
2016 Ottawa Yard...
