Issues with shimming IRV on a 445
   / Issues with shimming IRV on a 445 #1
Turbo Goat
Member
Oregon
John Deere 445 w/40 Loader
Hey tractor people,
I'm taking my first stab at modifying my 445 hydraulics. Aaaaaaannndd something's weird.
The first issue that I discovered was that the stock hydraulic pressure was 750 PSI. Not a good sign, but not necessarily a show-stopper. Second, the stock IRV seemed to be missing some packing and a washer, and it was also very worn. The brass shim was deformed into an oval in the ID, and the plunger cone was visibly worn. I received a new IRV today and began shimming. I pretty consistently get less than 50 PSI for each 0.3 mm shim. So at 1.2 mm of shims, I get 900 PSI. Now this seems WAY low. I can't reasonably put any more shims on and I think it would be asking for trouble anyway. I'm about to conclude that the charge pump needs an overhaul. However, I could be missing something. So I want to ask the community for a sanity check.
The hydraulic fluid is full. The fluid and filter were very recently changed. The fluid is HyGard, Low Vis. Pressure is measured at W.O.T.
My assumptions are:
1) The stock hydraulic pressure in a properly functioning system should be about 950-1050 PSI.
2) Most people that have made this mod get around 1250 PSI with 0.5-0.6 mm of added shims.
3) It is OK to measure charge pump pressure at the bucket wrist, raise port (top left looking forward).
4) It is OK to use a cheap 2000 PSI gauge, cobbled together with some fittings from ebay to measure the pressure.
5) Visible wear on the IRV sealing surface is indicative of a problem. This problem could have been caused by the missing packing, allowing the plunger to wobble.
6) The machine has about 2000 hours on the meter, and I suspect that it was not so well maintained. It's a '97. So, some wear is to be expected.
7) A charge pump rebuild is improbable, and replacement of the transaxle is likely the only solution.
When I ordered the IRV, I thought about ordering the valve seat as well, but the JD parts diagram doesn't give a number for it. I'm not sure if valve seat wear would have an impact on pressure when mated with a new plunger. I'm not sure if I could get it out of the transaxle case anyway.
If anyone has any ideas, questions that might lead to a solution, or useful info, I would really appreciate the help.
   / Issues with shimming IRV on a 445 #2
Missing what you are calling the "IRV"
OK, found it.. Implement Relief Valve..
Hi beenthere,
The IRV is the Implement Relief Valve. It is located on the top of the transaxle. It's purpose is to regulate charge pump hydraulic pressure to the lift and attached accessories.
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Mahindra Max26Xlt Like New
Mahindra Max26Xlt...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
John Deere 7000 8R Planter (A59814)
John Deere 7000 8R...
