/ Share Pics of People Hauling or Towing Something Wrong #6,382
Terrorist suicide bomber?
This would make sense if he had already filled the cans with fertilizer (ammonium nitrate) and is filling them with diesel. That would make a very big boom.
/ Share Pics of People Hauling or Towing Something Wrong #6,383
We also got them here in New Hampshire.:rolleyes:
/ Share Pics of People Hauling or Towing Something Wrong #6,384
Stupid people? Heck, around parts of here there's so many you have to take a number. No pictures but some things I've seen are just poking Darwin to call them home.
/ Share Pics of People Hauling or Towing Something Wrong #6,385
I love that last phrase for soooo many reasons! :laughing:
/ Share Pics of People Hauling or Towing Something Wrong #6,386
Poor guy just needed to make sure his burn pile lit off properly after all the rain from Harvey.
I will neither confirm nor deny that I might have a friend who may have hauled 30 gallons of gas home from the station in those orange Home Depot buckets with lids. That was just before Hurricane Rita.
/ Share Pics of People Hauling or Towing Something Wrong #6,387
30 gallons in buckets with sealed lids is a little bit different than 50 gallons in a container that will not seal and could flood the truck bed with gas if you had to punch the brakes...
Aaron Z
/ Share Pics of People Hauling or Towing Something Wrong #6,388
Aaron Z
Very true. Different degrees of silliness to be sure...
wb-DumbAndDumber_SVOD-Full-Image_GalleryBackground-en-GB-1484002836625._RI_SX940_.jpg
/ Share Pics of People Hauling or Towing Something Wrong #6,389
... I might have a friend who may have hauled 30 gallons of gas home from the station in those orange Home Depot buckets with lids. That was just before Hurricane Rita.
Heck I sometimes use the 5 gallon UTF buckets for that, the ones with a pouring spout in the lid. I think all those paint-type 5 gallon buckets are the same material and are DOT-rated.
But an open garbage can????
/ Share Pics of People Hauling or Towing Something Wrong #6,390
Years ago the underground fuel tank was compromised and water got into it.
It had recently been filled with about 900 gallons remaining.
My job as a kid was to fill a 30 gallon metal garbage can with gas.... let it settle for a few hours and then siphon off the gasoline by drawing from the top of the garbage can... filled all the tanks of the cars at the Dealership... took better than a week.
Good thing I was not a smoker!!!
The simple and crude method worked well as far as separating the water from gas although I imagine it could have been done with filtration.
/ Share Pics of People Hauling or Towing Something Wrong #6,391
Static electricity would have been a likely problem on all that transferring, moving and hauling around the lot.
/ Share Pics of People Hauling or Towing Something Wrong #6,392
Sounds like they were lucky that was before ethanol. Ethanol would have absorbed a fair bit of water & not let it settle out easily.
/ Share Pics of People Hauling or Towing Something Wrong #6,393
The assumption here is that it's gasoline. I look to store/haul no more than 5 gallons of gasoline.:eek: Bulk storage, other than my propane tank (used very sparingly, for household cooking and the clothes dryer), is diesel. For sure, if they're filling "containers" like that with gasoline then that's really a bad idea!
/ Share Pics of People Hauling or Towing Something Wrong #6,394
Well, the pump isn't green so that's a pretty safe assumption it's gasoline. I can't make out the name of the gas station but the sign isn't BP colors. The reason that's worth mentioning is BP is notorious for using the wrong colored pump nozzles.
/ Share Pics of People Hauling or Towing Something Wrong #6,395
Ha ha. The "only" way we could use the word "safe" here is via "assumption" (and on our recognition of the situation, not on any function or execution).:laughing: This is SO wrong... But, human nature and all... Lots of folks in other parts of the world end up getting blown to bits trying to salvage fuel from turned over tanker trucks which end up exploding (surprise!).
/ Share Pics of People Hauling or Towing Something Wrong #6,397
I am an expert dumb a-s I would do the paint bucket with lids stunt. I will remember that just incase! The garbage cans though..........I'm a dumb a-s not a moron.
/ Share Pics of People Hauling or Towing Something Wrong #6,398
You just can’t make this stuff up!
/ Share Pics of People Hauling or Towing Something Wrong #6,399
Is it just me, or is he dragging the exhaust as well? (In happy's post above)
Appears it is broken and dragging between the rear wheels in the second/side picture.
2012 Kubota M108S 108HP 4WD Agricultural Tractor with Bush Hog 2615L1 15ft. Rotary Brush Cutter (A59228)
2012 Kubota M108S...
24in pin on excavator tooth bucket (A61306)
24in pin on...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
