M7060 - Can additional rear wheel weights be added if the tractor has cast centers?
   / M7060 - Can additional rear wheel weights be added if the tractor has cast centers? #1
mbu
Colorado
Thanks...
   / M7060 - Can additional rear wheel weights be added if the tractor has cast centers? #2
I don't think so, at least that is what my dealer said. If you already have cast centers, are your tires ballasted with fluid? I have cast rears on my M7060 and they are water ballasted and I don't think I would ever need more weight.
   / M7060 - Can additional rear wheel weights be added if the tractor has cast centers? #3
Kubota website for M7060 shows one can add up to 3 sets of rear wheel weights but doesn't mention cast or steel wheel centers. If weights can't be added then I wonder why there are holes in cast centers other than holes for mounting to axle & wheel?
   / M7060 - Can additional rear wheel weights be added if the tractor has cast centers? #4
My cast wheels have a 3 & 4 bolt pattern in them, I always thought to accept additional weights. Maybe it's not the same on a M9540
   / M7060 - Can additional rear wheel weights be added if the tractor has cast centers? #5
I just looked at a picture of my cast wheels and they have the 3 and 4 bolt pattern also, total of 7 holes. I think my dealer has just saying, with the cast wheels and filled rears there was no need for spending more money on additional weights and I agree, unless you did not have filled rears and wanted to add or remove weight.
   / M7060 - Can additional rear wheel weights be added if the tractor has cast centers? #6
If you go to Lonestar weights or Everything attachments you can find a lot of weights, and there mounting patterns, circle diameter and 3 or 4 hole.
I have 300# weights on my tractor, 4 of them considering a couple more.
I do not like filled tires, over the years they have cost me a lot more then iron does.
   / M7060 - Can additional rear wheel weights be added if the tractor has cast centers? #7
Yes, you can add rear weights to the cast wheels. It's no big deal and is done all the time. I do it and have pics of others doing it as well. You can have cast and add up to three sets although two sets is plenty. Not sure if I would do it with liquid in tires since people usually do one or the other.
   / M7060 - Can additional rear wheel weights be added if the tractor has cast centers? #8
Yes, you can add weights to cast centers, at least we did to our M125X.
I bought 3 sets that were all going to be put on my M7040 but I didn’t like how the 3rd one stuck out past the rim. I went ahead and put that set on my M125X w cast wheels.
   / M7060 - Can additional rear wheel weights be added if the tractor has cast centers? #9
Oh, the three or four mounting holes in the weights is because earlier versions of that tractor, the M6800, M8200 and M9000 had a three bolt pattern and those weights are still around. Those look more like a fat washer and it's hard to hook up multiple sets. Avoid them. I have a pic somewhere if anyone wants to see it and I can find it. You cannot mix and match three and four bolt weights.
Wait, here is the three bolt weight.
   / M7060 - Can additional rear wheel weights be added if the tractor has cast centers? #10
Thanks...
Yes.
I have cast weights on the cast centers of my M9960.
I change my own tires so never use liquid ballast.
SDT
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52705)
2017 FECON RTF140...
2005 Bomag BW266 Double Drum Roller (A54865)
2005 Bomag BW266...
2015 Dodge Grand Caravan (A55758)
2015 Dodge Grand...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
