Yt359 cat I hitch?
   / Yt359 cat I hitch? #11
How do you put a smaller bushing on a bigger diameter pin :confused3: CAT 2 tractor WILL work on CAT 1 implement with a bushing BUT Cat 2 implement WILL NEVER FIT IN A CAT 1 tractor LOWER ARM
Fixed it....for clarity.....:)
   / Yt359 cat I hitch? #13
The manual for YT347/359 suggest the largest mower is 7', so an 8' mower may be more than what the tractor can handle.
I attached screenshots of the relevant pages.
   / Yt359 cat I hitch? #14
Ray,
My MX and your tractor are similar in size and lifting capacity. I use a Befco 9 ft 2 " finish mower with no issues, about 1500 lbs w/o looking up the exact spec.
   / Yt359 cat I hitch? #16
What would be the largest rotary mower that you'd want to pull with the YT359.
   / Yt359 cat I hitch? #17
V53,
The seven ft single gearbox twin swinging blade is very inefficient. To much time lapse between cutting surface contact. You can purchase a semi- trail model, 8 ft or even 10 ft that transfers weight back onto cutter. 10 ft may scalp on uneven terrain. Also 7 ft produces excessive windrows. Take a look at Kodiak brand rotary cutters for comparison and hp required ratings.
Beaver Valley Supply .com has kodiak literature, specs, photos, prices for comparison.
   / Yt359 cat I hitch? #18
V53,
Thanks for the information. I might look into Titan, since it's made locally here in Tennessee. I think they split from Kodiak, so it would be good to compare the two
   / Yt359 cat I hitch? #19
I used to pull a twin blade 8' pull-style mower with my Massey 1652 (which is very close in spec to this Yanmar)... It handled it fine. But a flail can be a bit more demanding.
I sold that mower and only use the 90" flail now.
   / Yt359 cat I hitch? #20
How do you put a smaller bushing on a bigger diameter pin :confused3: CAT 2 WILL work on CAT 1 with a bushing BUT Cat 2 WILL NEVER FIT IN A CAT 1 LOWER ARM
Replace the cat 2 pin with a cat 1 so it fits inside the cat 1 arm, then cat 1 to cat 2 bushings where the pin goes through the implement. Would require two bushings on each pin, or use a dual category pin with one bushing on each side.IMG_0113.JPG
2025 IRGC40 Mini 3 60v Electric Tricycle (A56859)
2025 IRGC40 Mini 3...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
2023 Landhonor Square Hay bale Grapple (A57454)
2023 Landhonor...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
