Yt359 cat I hitch?
   / Yt359 cat I hitch? #11
How do you put a smaller bushing on a bigger diameter pin :confused3: CAT 2 tractor WILL work on CAT 1 implement with a bushing BUT Cat 2 implement WILL NEVER FIT IN A CAT 1 tractor LOWER ARM
Fixed it....for clarity.....:)
   / Yt359 cat I hitch? #13
The manual for YT347/359 suggest the largest mower is 7', so an 8' mower may be more than what the tractor can handle.
I attached screenshots of the relevant pages.
   / Yt359 cat I hitch? #14
Ray,
My MX and your tractor are similar in size and lifting capacity. I use a Befco 9 ft 2 " finish mower with no issues, about 1500 lbs w/o looking up the exact spec.
   / Yt359 cat I hitch? #16
What would be the largest rotary mower that you'd want to pull with the YT359.
   / Yt359 cat I hitch? #17
V53,
The seven ft single gearbox twin swinging blade is very inefficient. To much time lapse between cutting surface contact. You can purchase a semi- trail model, 8 ft or even 10 ft that transfers weight back onto cutter. 10 ft may scalp on uneven terrain. Also 7 ft produces excessive windrows. Take a look at Kodiak brand rotary cutters for comparison and hp required ratings.
Beaver Valley Supply .com has kodiak literature, specs, photos, prices for comparison.
   / Yt359 cat I hitch? #18
V53,
Thanks for the information. I might look into Titan, since it's made locally here in Tennessee. I think they split from Kodiak, so it would be good to compare the two
   / Yt359 cat I hitch? #19
I used to pull a twin blade 8' pull-style mower with my Massey 1652 (which is very close in spec to this Yanmar)... It handled it fine. But a flail can be a bit more demanding.
I sold that mower and only use the 90" flail now.
   / Yt359 cat I hitch? #20
How do you put a smaller bushing on a bigger diameter pin :confused3: CAT 2 WILL work on CAT 1 with a bushing BUT Cat 2 WILL NEVER FIT IN A CAT 1 LOWER ARM
Replace the cat 2 pin with a cat 1 so it fits inside the cat 1 arm, then cat 1 to cat 2 bushings where the pin goes through the implement. Would require two bushings on each pin, or use a dual category pin with one bushing on each side.IMG_0113.JPG
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
Service Truck (A59230)
2024 Timpte 40ft Hopper (A56438)
2024 Timpte 40ft...
207269 (A52708)
207269 (A52708)
(22) Assorted Webbing Slings (A57453)
(22) Assorted...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
