OK so what's the drill? How do I get this @#$*&^+ back hoe back on the tractor?
/ OK so what's the drill? How do I get this @#$*&^+ back hoe back on the tractor?
Re: OK so what's the drill? How do I get this @#$*&^+ back hoe back on the tractor?
Maybe the two plates that make up the tractor portion of the 4pt have been forced inwards or outwards during your tractor use. And they do not have the same spacing that they did when you took the hoe off. They are just bolted to the axle with those big bolts, and it would not be hard to bang into something and maybe get one to move. My plates were a little too far out and I moved them in a little to give me a little more side slop to get it on/off. I am sure there is some side to side slop in the bolt holes in the 4pt part that bolts to the hoe, too. Not much, but maybe enough to help you out. I know that the ' putting the durn thing back on ' can be a pain somedays. The problem is that moving the bucket, the stick, or either of the stabilizers changes the geometry of what you are attempting to do in about a million different directions/angles. And the attitude of the person wiggling the control sticks can sometimes be a problem. Just the simple thing of lifting the hoe up in alignment with the tractor 4pt, backing the tractor up a little, and then drop'n in place sounds easy. Somedays it is..... :) If you get too frustrated, I have a couple shovels I can lend you so you can still dig.... [[[ :) ]]]
It's not a spacing issue it's a knucklehead user issue. Nothing is bent because I've done nothing with the rear of the tractor 3pt or PTO wise. Since I took the hoe off all I've done with it is push some snow around.
If the BH is tipped away from the tractor it should allow the pins to fully engage the hooks as you lower it. Then tip the BH back toward the tractor to engage the upper attachments.
I know all that stuff and how it should work but it ain't. I've been through this exercise before. Now that it's on the ground I'll get someone to help spot me as I back into it. But somehow someway this should be easier than it is.
/ OK so what's the drill? How do I get this @#$*&^+ back hoe back on the tractor? #43
Do you have a tractor or a fancied lawn mower? You ain't moving my tractor by hand, especially off pavement or the hoe either unless it's on the dolly.
A tractor. I've done it for years! Not hard for me just use the back tire treads for leverage. I roll trailer loads of stuff around by hand also...not hard for me at all. As long as I can remember I've carried and moved heavy stuff.
/ OK so what's the drill? How do I get this @#$*&^+ back hoe back on the tractor? #44
Maybe is is an operator ' age ' issue.... [[[ :) :) :) ]]] I have extra problems with mine sometimes... but it is usually because I am not holding my mouth right... Since I got my third Mahindri, I just leave it on....
/ OK so what's the drill? How do I get this @#$*&^+ back hoe back on the tractor? #45
Here's my little lawn mower. I'm 65, maybe I'm missing something, but it should go on easily. I think pictures would help to figure out what's wrong. I just removed mine, then back on. Tractor now has 110 hours, hoe maybe 15. It's easier each time. As someone suggested I think something is bent, out of line, worn, etc.
I just use stabilizers and roll the lawn mower back and forth as needed. Easy. 20180606_183834.jpeg20180606_175209.jpeg20180606_183846.jpeg20180606_183912.jpeg
/ OK so what's the drill? How do I get this @#$*&^+ back hoe back on the tractor? #46
BTW on my tractor the hole bosses are on the tractor and the matching holes and guides are on the body of the hoe. Sounds like exactly opposite of yours.
Yep yours is exactly like mine. See those C shaped guide dohickeys welded to the inside? Those hit the top of the pin bosses when I try to rotate the hoe so the pins will engage the hooks. If they were open toward the bottom instead of directly forward I would not be having the problem with the hoe on the dolly as they would tend to aid not hinder things.
notice the hook below the chain and the top boss... is that the same?
Looks the same.
I just use stabilizers and roll the lawn mower back and forth as needed. Easy.View attachment 557407View attachment 557408View attachment 557409View attachment 557410
I think the problem is that it's incompatible with the hoe on the dolly I made. I put it on the ground and with someone helping to spot me I'll probably get it on. I'm not gonna do it single handed because I liable to break something if I keep at it.
Yours looks completely different. For starters my 3pt has to be removed before I even start. It's tight for space back there. I mean really tight.
/ OK so what's the drill? How do I get this @#$*&^+ back hoe back on the tractor? #53
I sure wished I was there to see it. Something is obviously wrong, it shouldn't be that tight clearance either. I keep a zippered canvas bag mounted under seat which holds lots of tools, pins, etc. So I easily and quickly can loosen hitch turnbuckles out of the way, then adjust for Bush hog, etc.
It should be almost effortless.
ok how tall is your dolly?
Don't know off hand but I think the casters are 6" heavy duty for the load rating bolted to a 4 X 6 crosspiece laying flat so maybe about a foot. I had to modify it once already to allow the frame of the hoe to rotate more, lower, so I could get the hoe off. The frame of the hoe pivots on the crosspiece. I think it may be a tad high yet. The casters are rated at 600lbs each. I'm using two fixed and two swivels and the hoe weighs about 1200 lbs. I could either get smaller casters if I can find smaller that will take the load or maybe back the back tires of the tractor up onto some 2 X 6s, 4 X 8s or something. I'll study on it later.
/ OK so what's the drill? How do I get this @#$*&^+ back hoe back on the tractor? #55
My woods was a real pain the first few times, even after I learned how.
Seems like after using it a few times, the tolerances between all the parts loosened up and it got better.
It's like ***, you need to lubricate the mating joints. Axle grease smeared on contact points is a recommended step in the manual for my KMW 3710 backhoe.
Yeah well this critter is far from effortless. I'll get it sooner or later. I always do. Some times it's easy and some times ya gotta think harder.
I wish you were here too. Bring some barbeque when you come will ya.
This ain't got nuttin to do with lube. It's about two solids trying to occupy the same space at the same time and I know enough physics to know that ain't gonna happen.
/ OK so what's the drill? How do I get this @#$*&^+ back hoe back on the tractor? #58
No, it's not near as fun. I tried spitting on the hoe, but it still didn't fit.
I wish I'd thought of driving the tractor up onto something to get it a bit higher earlier. But I was too tired, aggravated, and too POd to think then.
/ OK so what's the drill? How do I get this @#$*&^+ back hoe back on the tractor? #60
It's a Mahindra, right? I would go by the dealer and talk to them. Take pictures of it, maybe something installed improperly.
I was laughing WITH you at first since it took both of us so long the first time. Then my 5 watt light bulb came on and now it's a piece of cake.
If it's one thing I learned over the years it's smarter not harder. So many things it's proper alignment, grease, leverage.
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A59230)
2008 Featherlite...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
