Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,302
What kind of test are you doing to determine the internet is down?
Log onto router network...log into router...no internet, nor will my browser reach anything. Router says to connect the cable....it's connected. Log on to Mobley, got internet etc....right now can't go into the details of the Mobley...password issue, looks like I'll need to do a factory reset....and I had all of the passwords documented, just none of the work. SO....something happened not sure what.
To tired to look into it now, maybe tomorrow. Had big work day in yard, and I'm wore out.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,303
Re: Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
How did you know to do that?...i need to dig into mine...it's like the cable is not connected.
It's the same effect as the cable disconnected.
Go into AR router, advanced settings, network. Here is snapshot of the screen. 0611181822.jpeg
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,304
Mine seem to be working per normal.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,305
What is the error on your browser?
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,306
Since you get internet with your mobley, i suspect the router. What router, and does it use the mobley input as a modem?
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,307
GL-AR150-4b6 router and yes usb cable to Mobley.
Obvious in router view it says cable connection for internet not connected.
I tried to find the setting under advance, network, to set usb2 from usb0, but router screen different than yours and can't locate.
It simply acting like the cable isn't plugged in.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,308
When connected to mobley, you should see modem connection data like this. If not connected, this will be blank.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,309
I will look up and send exact steps tonight...View attachment 558171
YES...and it is blank. The red status light on the GLAR150 is blinking...should be solid. Maybe I should try a different cable, but a cable going bad would be strange.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,310
On one of the AR pages, maybe network page, there is link near top that says something like advance features. When you click, you get another login page. This takes you into linux level interface with a lot more options.
New/Unused AGT Industrial QHT500FL Mini Tracked Dumper (A57453)
New/Unused AGT...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2 Disc Heavy Duty Bottom Plow (A57454)
2 Disc Heavy Duty...
PREVIEW DATES AND TIMES (A57454)
PREVIEW DATES AND...
Kubota RTV X900 (A53317)
Kubota RTV X900...
SUV (A59231)
SUV (A59231)
