Mahindra 2538 6' bounces
   / Mahindra 2538 6' bounces
It ended up being a bad relief valve for the 3 point hitch, covered under warranty
   / Mahindra 2538 6' bounces #12
Thanks for closing the loop.
Good news. I had thought that relief valves only acted during lift - not hold. My Kubots are that way I know. If my 7520 acts up Ill keep it in mind.​
   / Mahindra 2538 6' bounces #13
You need to realize there are two relief style valves on the 3 pt hitch.
The normal one which limits how much weight it will lift.
The second one, usually called a safety valve, is in the cylinder circuit when you are traveling with a heavy implement on the 3 pt.
The safety valve's purpose is to protect the 3 pt against the loads caused by bouncing implements.
The safety valve has to be removed and tested on a fuel injection machine as its release pressure is much higher than the tractor's hydraulic system can develop.
This schematic is from a Kubota but other brands are similar.
Dave M7040
   / Mahindra 2538 6' bounces #14
Dave M7040
Ah! That makes good sense. I think the L3450, an older Kub, does it with a rupture disc.
The rocker arm on mines rocker shaft broke and during fix I saw what I thought was a rupture disc setup that had failed to protect it.​
   / Mahindra 2538 6' bounces #15
I do not know for certain but the use of a rupture disk in a farm tractor would be most unusual. The manufacturer is designing to protect the equipment not to put it out of service which a rupture disk would do. Further, with a rupture disk the manufacturer risks someone using something else to get the machine back working.
I am not saying you are not correct just that I have not seen it done and I can see lots of reasons why it would not be done.
If an amateur was messing around trying to increase the lifting power of the 3 pt and inadvertently changed the safety valve then real mechanical failures would happen.
Dave M7040
COIL TUBING FRAME (A50854)
COIL TUBING FRAME...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2013 FOREST RIVER WILDWOOD BUMPER PULL CAMPER (A50854)
2013 FOREST RIVER...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
