Mahindra 2538 6' bounces
   / Mahindra 2538 6' bounces
It ended up being a bad relief valve for the 3 point hitch, covered under warranty
   / Mahindra 2538 6' bounces #12
Thanks for closing the loop.
Good news. I had thought that relief valves only acted during lift - not hold. My Kubots are that way I know. If my 7520 acts up Ill keep it in mind.​
   / Mahindra 2538 6' bounces #13
You need to realize there are two relief style valves on the 3 pt hitch.
The normal one which limits how much weight it will lift.
The second one, usually called a safety valve, is in the cylinder circuit when you are traveling with a heavy implement on the 3 pt.
The safety valve's purpose is to protect the 3 pt against the loads caused by bouncing implements.
The safety valve has to be removed and tested on a fuel injection machine as its release pressure is much higher than the tractor's hydraulic system can develop.
This schematic is from a Kubota but other brands are similar.
Dave M7040
   / Mahindra 2538 6' bounces #14
Dave M7040
Ah! That makes good sense. I think the L3450, an older Kub, does it with a rupture disc.
The rocker arm on mines rocker shaft broke and during fix I saw what I thought was a rupture disc setup that had failed to protect it.​
   / Mahindra 2538 6' bounces #15
I do not know for certain but the use of a rupture disk in a farm tractor would be most unusual. The manufacturer is designing to protect the equipment not to put it out of service which a rupture disk would do. Further, with a rupture disk the manufacturer risks someone using something else to get the machine back working.
I am not saying you are not correct just that I have not seen it done and I can see lots of reasons why it would not be done.
If an amateur was messing around trying to increase the lifting power of the 3 pt and inadvertently changed the safety valve then real mechanical failures would happen.
Dave M7040
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
2014 Dodge 5500 4X4 Bucket Truck (A51039)
2014 Dodge 5500...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2018 VOLVO VNL...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
