Iseki engines
   / Iseki engines #11
JWR,
Nice post. I'm a little surprised at the bx cooling issue, as both the Yanmar design (like the sc2400/2450 etc.) or the Massey GC1700's seem to not develop heat - period. In fact, the only way I can get the temp gauge on my GC1715 to go above the 1/4 temp level is to not clean the screen for quite some time.
It always seemed the bx radiator etc. was ample in size - but is there some type of spot where flow restriction might occur? (like in a pipe turn entering into the radiator, or some "buildup" in the radiator?) Is there a pressure test on the cooling system that would indicate resistance buildup compared to the water pump test for pressure/flow ? Your thought that the pump might be a little light on flow pressure would cause your description - but it would seem that Kubota over a 15 to 20 year timeframe would have had too many complaints develop that they would have switched in a slightly larger flow pump. However if there is a restriction point - then a slightly larger pump would likely not correct it.
Because it seems that Iseki, Yanmar, and Kubota all share an appreciation for the numerous benefits of forward cooling in the 18 hp to 25 hp 3 cylinder diesel engines - I would think it would show up enough in competitive issues for Kubota to have seen and solved the problem. As Atsah was commenting with his gc1705 - I was actually a little concerned that somethg was wrong with my unit last year when it was 100 degrees outside and I was mowing for 4 or 5 hours with my mulching deck (which creates more load than a normal mowing deck) - and it didn't even move the needle.
   / Iseki engines #12
JWR,
I'm a little surprised at the bx cooling issue, .... getting the guage up to the 1/4 temp level is to not clean the screen for quite some time.
It always seemed the bx radiator etc. was ample - but is there some type of spot where flow restriction might occur? (like in a pipe turn entering into the radiator, or some "buildup" in the radiator?) Your thought that the pump might be a little light on flow pressure would cause your description - but it would seem that Kubota over a 15 to 20 year timeframe would have had too many complaints develop that they would have switched in a slightly larger flow pump. However if there is a restriction point - then a slightly larger pump would likely not correct it.
Good points. I never thought about a bend or a constriction someplace. I'll look. I flushed the cooling system a couple of years back but have no good way to tell if it is partially plugged. ALL of the BX machines I've worked with are/were used. Though mine only had 200 hours on it when we got it in 2002. If there is a partly clogged radiator, it must be with "all" of them ("all" in my case being the 3 BX I have worked on.) I am very puzzled, like you, that Kubota has done nothing about this in 20 plus years. It does not seem that I am doing anything unusual or neglecting the cooling system. Maybe because it never goes "over the top" and blows out the antifreeze that I know of (just gets into the red) that so many people never look further or ignore it. Still strange I think. They do run poorly when they get that hot -- even to the point of extensive use of the power steering starting to bog down the engine.
   / Iseki engines #13
Very pleased with the Iseki engines I've had in my Iseki-built Massey machines. Never gave me one spec of problems, very reliable.
Iseki makes the whole machine, not just the engine...
   / Iseki engines #14
Is there a thermostat in the path of the water flow on the BX??? I wonder if that is the restriction point.
   / Iseki engines #15
That's a question I can't answer. . . But a good one to consider.
Another good question is. . . has distilled water been used consistently for the radiator needs.? Here's why that is important. Let's say there has never been a tendency for the temp to rise. In that scenario it's unlikely there is a restriction point so iron or other buildup is not a big issue (though I'd still use distilled water). By if there is already a history of temp rising (for whatever reason) . . . . Water/fluid quality becomes a much bigger issue. Think of it like a creek or a river stream, any spot that shows flow restriction automatically become a collection apt for silt or leaves or branches. Same story in coming systems. And compounding the issue is if water is coming from a farm or country well, you can have non-solable and soluble iron or other minerals. Any of those is a problem. . but too often users think only in terms of water 'clarity".
Coming from our well we have iron soluble water . . . taste great and clear as the glass it's in. . . . . but let that water stand in the glass for 4 days and the irony settles to the bottom and makes a believer of you to have a whole house filter right after the water line comes in the house.
   / Iseki engines #16
Back to the Iseki engine topic, I really like how well Iseki designs the whole tractor to work with the engine. Iseki seems to prefer "robust" designs and I expect if they redo the 1500 series or at least the 1526, That they will add what looks like a slightly larger GC look and modernization but with the many features that the 1526 sports and some type of color and seat updates too.
Personally, I think the 1500 series could be no more than 1 or 2 sizes much like the starting kubota B series models offer. Would be a smoother transition for many would be buyers without the gap that the 1700 series creates. Jmho
   / Iseki engines #17
My 1705 cooling is very good I mow about 4 acres every week and with the temperature in the 90's it never gets to the first line as long as I keep an eye on the screen but it still doesn't get the that hot to worry about I just let it cool down before I shut her down at the end of the day.
   / Iseki engines #18
My little mf 1531 had an iseki engine. While it definitely was no power house, it seemed to be a good little reliable engine. It did tend to run a little hot if working it hard in summer heat. It also would not start in cold weather. ??? Could of had posibbly a bad glow plugs or something, I don't know??? I junked the tractor, it was a POS. The engine and hydrosat were probably the only things on the tractor that were decent.
   / Iseki engines #19
I thought you were going to let me buy it from you when you were done with it...?
   / Iseki engines #20
It needed ten thousand dollars worth of work done to it and we was in a hurry
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
Kubota M5-111 (A53317)
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
