IH 484 clutch shaft wear question
   / IH 484 clutch shaft wear question
I refere to the splinedboss of the clutchplate
So the distance from the splined boss of the clutch plate to the tip of the fingers should be 50mm?
Sorry for the confusion and thank you for patience
   / IH 484 clutch shaft wear question #42
If you look at that spesial tool (pilotshaft) you wil see that that thick diameter can only rest against the clutchplate boss. From there to the fingers must be 50mm or near 2"
Understood. Thank you for clarification. I will split the tractor next week and measure the distance to the fingers.
ANY NEWS about your clutch ?
Hello DLTTrekkers. I haven't disappeared :) I haven't had a chance to make it out to the tractor yet as it is at my friend's house - I have been extremely busy at work. While waiting I ordered a new pressure plate and a clutch tool. They made it in. So next time I go I will be putting a new pressure plate on. When I do I will post an update. Good day!
   / IH 484 clutch shaft wear question #46
No payment needed !
No payment needed !
I got out to the tractor. Broke it in half again. Checked the old pressure plate . The fingers are 55 mm from the clutch boss. I installed a brand new pressure plate. The fingers were at the same distance. I checked the fork and it is installed correctly - that is the same way it came out. I also checked the clutch fork shaft and it does not have any cracks in the arm. I am at loss here.
   / IH 484 clutch shaft wear question #48
That 55....is it when installed and tightern on the flywheel or is that when its not installed ?
   / IH 484 clutch shaft wear question #50
The outside adjustible link must be allmost screwed out to about full lenth
2013 John Deere 824K (A53472)
2013 John Deere...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A53472)
2004 Capacity Yard...
(4) 5 LUG GRAND PRIX ALUMINUM WHEELS (A51248)
(4) 5 LUG GRAND...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
