Yanmar YM2000 Fuel Pressure/ hard starting
   / Yanmar YM2000 Fuel Pressure/ hard starting #161
Good to hear.
   / Yanmar YM2000 Fuel Pressure/ hard starting #162
:cool2: Looks like a success story. Probably will need to confirm whether your tach cable is good.
   / Yanmar YM2000 Fuel Pressure/ hard starting #163
try to tighten your tack cable up at the back of the tach. Give it a few taps with a screwdriver handle maybe the gears are stuck? There pretty simple things. They have plenty of them at Hoye if you need one, and i suggest having a working one. I don't think the two are related, just probably some worn spots on 40 year old parts!!
And this is good news about the tractor. I bet it runs fine for 20 more years!
whats the warning light on the dash for?
Warning light is battery light. The alternator has been converted to a GM single wire, and the factory box has been cut out of the wiring harness. That’s another project on this thing I’d like to get taken care of, turning that darn light off. Haha
   / Yanmar YM2000 Fuel Pressure/ hard starting #166
if you don't care about knowing if your not charging, just pull the bulb!!! a hack fix that i would not like personally, but with these once your going your going. Your lights may not work but your tractor will still run, you don't even need the battery once started for daytime. hehe
That’s a thought, I just won’t do that though. Haha eventually I’ll fix it. Maybe.
Need to get new nuts for the headlight switch too.
   / Yanmar YM2000 Fuel Pressure/ hard starting #168
If you could make a GM three wire alternator work, I believe that would fix the light, would come on when not charging and go out when it was. The original regulator was what made that work.
Gotcha, I’ve got a Ford 3 wire sitting here from the boat engine, but the alternator on the tractor is brand new, and is 90amp vs the factory 50 or whatever it was it came with.
   / Yanmar YM2000 Fuel Pressure/ hard starting #170
Be hard to make the light to turn off with the single wire model.
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
backhoe attachment for mini skid steer (A53421)
backhoe attachment...
Hand Truck (A52377)
Hand Truck (A52377)
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
