New garage and home build
   / New garage and home build #11
And what eddie said about mandoor frame rotting is true, mine has rotted at less than 10 yrs.
First. My plan is to store our RV, F150 truck, small tractor, snowmobile trailer, have a workshop and some storage such as implements. The first thing to come our would be the sled trailer if I run short of room.
Are you going to park three cars in those three garage doors? 9ft doors are super cheap, ten foot doors jump in price. I've never heard of or seen a 9ft 6inch door, so that must mean they are being custom built. To me, that's just a waste of money.
That must be the ro Eddie cuz I'm sure the doors are 9'w
There really is no room to open a door once you have three cars in there.
I will look at that.
How wide is that big door on the other side? Ten foot is what I would consider the minimum, and that can be really tight if you want to get a trailer in there or an RV, or anything with big mirrors on the side of it. Mine is ten foot wide and my next one will be 12 foot wide.
12wX14H
Where will you store stuff? Will there be a work bench? Shelves should be two feet deep to hold anything at all. Same thing with a work bench. I wouldn't wan anything smaller. You have two long walls that would make great storage, but you only have a foot from the wall to the three doors. That really need to be four feet so you can have storage and park a car.
I hope to have space in the rear for a workspace, bench and table saw of course min. 2' deep bench
Do you have a porch over your walk through doors? They will rot on you if not protected. Every walk through door should have a some sort of roof over it to keep the rain from getting into the seals and rotting out the frame. This starts at the bottom and works its way up. It starts the day you install it and it just depends on how much weather you get as to how fast the rot proceeds.
None in plans but I will have one now!
I really, strongly suggest having a sink inside that you can wash things. Mine is close to the walk in door, and it's used all the time!!!!!
This garage is 90' from the rear of the home we are now building and although I was planning on a water spigot, I will likely blow that out for the winter. Sink?? Dunno about drainage.
To be truly helpful, we need to know what you are going to use this building for, and what you plan on putting in there. In my opinion, seeing those three doors, I think that you are building it too small.
The original was 30X40 but I've pushed the budget with the wife so I can get 34X42. Remember, I'm not a tradesman, just a guy with some toys. ;)
   / New garage and home build #13
36x48 to gain a little width for 3 garage doors? (It's easier to spend other's money)
My first thought was if it is possible to rotate the garage 90 degrees and so you could have three 12' doors on your 42' wide wall?
The minimum here for sheer was 18" between doors and now it is 24"
I own a nice home but is has three 8' wide doors... it sure does limit and make it tight unless you drive small cars... the previous owner had a Mini and a Miata and BMW... they fit OK... but two were only 2 seat cars.
   / New garage and home build #14
My garage is 24x30 with 2 9ft wide doors, 2 ft on sides and middle.
Sides should be 4 ft min, so you have vehicle entry, storage room.
Then my barn is 30x48, and too small.
   / New garage and home build #15
I have a 22 x 30 and with 2 9 foot doors... it is OK if there in nothing but two cars and a bench at the far end...
Many times I've said how nice it would be instead of 22 wide it was 24 wide!
The 30 is OK but 32 would be better...
   / New garage and home build #16
1) What type of truss do you have in mind to allow that tall of rear door??? It does not look doable.
2) Do you really need two man/walk doors? I would eliminate the rear one.
3) Depending on your plans for stall 3, you might want the side door further back, so you can walk across the front of any vehicle parked there. OR further forward, all the way to front corner, so you can walk behind anything parked there (just leave room to pull forward at least 3')
Very first thing I thought of.
   / New garage and home build #17
In snow country it's best to put your doors on the gable end if possible. Here's why;
This is what you get after you've plowed when the roof decides to shed it's snow.:laughing:
   / New garage and home build #18
Makes sense... "Almost" nothing I own is in snow country but of the two... one has a gable door to the rear of the property with distance being a problem and the other has doors on the side but the prevailing weather keep the snow at bay on the that side...
   / New garage and home build #19
Here's the roof cut away. I assume they are trusses but I'm no builder.
Compare this picture with you first picture of the rear. Notice where the top of door comes in relationship to the bottom edge of the roof. VERY different.
   / New garage and home build #20
Since it appears that both ends of the build will have a driveway to it, I think it is a good idea to have a man door on each end. 4' wide ones might let you use that door for more and not have to open the big doors and let the heat out. What will you use for heat? Some people in the frozen north do in slab heating for their shops. I've been in houses with floor heat and it's really nice.
Would you be putting a car lift in at some point? You will need extra width in one stall for it.
Lay out the bench and workshop equipment to see if there's enough room for everything. You can put tables saws and other equipment on casters but you'll still need storage room and floor space to move it to when you use it.
light tower (A56857)
New/Unused Hercules ATV Sprayer (A57453)
New/Unused...
New/Unused 2 Post Car Lift (A57453)
New/Unused 2 Post...
PARTS ONLY - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - 2023...
Hercules Rustic Gun Cabinet Holds 20 Guns (A57454)
Hercules Rustic...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
