DIY backhoe dolly
   / DIY backhoe dolly #1
Gofast
Gold Member
Greenville SC
MF GC 1725, 2016 MF GC 1710, Belarus 300
I used two harbor freight movers dollies one big and one small.
I then added some wood I had laying around and made this backhoe dolly.
I can now move it around by myself you need to make sure the garage floor is clean to keep the wheels rolling.
I know it does not look pretty but I made it with stuff laying around.
I really wanted to weld a nice dolly up but this did not take much time to build and was supper low cost.
   / DIY backhoe dolly #2
Looks fine to me! (I may be cheap, but I'm cheap.... :D)
   / DIY backhoe dolly
I used the dolly yesterday. I have a workhorse golf cart the has a power dump that I needed it to move some brush.
I was able to push the backhoe out of the way to get the cart out by myself.
I may have to put a coat of red paint on the dolly to make it look a little better.
   / DIY backhoe dolly #4
It gets the job done and you were able to use stuff you had, looks very functional!
   / DIY backhoe dolly #5
I can dig it! Rolls better than my oak splits and cement blocks :D
   / DIY backhoe dolly #6
Can you share how you determined the proper height for the control end of the backhoe? This is on my list of things to do.
I cannot decide if the height should be lower than the tractor and then use the stablizers to raise and then lower the unit onto the tractor. Or, higher than the tractor and use the stabilizers to lift it slightly and then lower it.
My chipper does not get used as often as I wish because of the pain of removing the BH.
   / DIY backhoe dolly #7
I use my little dollies sometime for my bucket when i leave it in the garage. Easy to move
   / DIY backhoe dolly #8
I made a dolly for my BH92. It is hard to move because of the weight of the BH, but once rolling it moves pretty good. PJohnson, mine is lower so that I can roll it into place under the BH while it is on the tractor and then use the out-riggers and bucket to lift it off the tractor and lower it onto the dolly.PA030003.JPGPB260001.JPG
   / DIY backhoe dolly #9
As mentioned above lower than the BH. I just built one with parts from Lowes. Four 200 lbs casters, a 2x10x6 and a 2x8x6. I used the scrap of the 2x8 to make a “seat” for the rear of the backhoe. I’ll take some pics if that helps.
   / DIY backhoe dolly
I just took the dolly痴 added enough wood to support the weight and tried it. It is a little lower but I did not want it higher so it would be stable.
I added a couple pieces of 2x6 under the out riggers to make it more stable.
I did not use the out riggers at all to put it on the dolly or take it off the dolly. It was very quick to put it on.
I just rolled it over lined it up connected hydraulics tilted back how backed up.
Used back how to line it up and pin it very quick.
   / DIY backhoe dolly #11
I made one this summer as well. The CB05 is a HEAVY backhoe, I intend on making one out of metal when I get some time.
   / DIY backhoe dolly #12
Also made a loader cart as well.
   / DIY backhoe dolly #15
I'm no help here... I splurged on a BXpanded dolly specifically made for my BH. I wasn't sure how precise the height needed to be. I am happy with it because I can remove/install it in a couple minutes. Knowing what I know now, I would have saved money on a DIY welded square tube frame. :ashamed:
   / DIY backhoe dolly #16
Yup. I bought the same BXpanded BH dolly. Works great!
   / DIY backhoe dolly #19
Sorry for the delay responding. Thank you. It was very helpful.
   / DIY backhoe dolly #20
I know this is late, but here's my version of a Kubota BH92 backhoe dolly. Not for everyone, but I designed it into 2 pieces for compact storage. I've used two ratchet straps. One for the outriggers and another that forces the boom against the backhoe mainframe via a notch on the backside of the boom keeper. Once in place it is very stable and moves easily. I chose to catch the dolly at the pins of the backhoe frame where it is the widest point of the backhoe. Do not attempt to design this unless you fully understand this.
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
UNUSED RAYTREE RTSG30-30" HYD STUMP GRINDER (A60432)
UNUSED RAYTREE...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A60430)
2015 CHEVROLET...
2012 Chevrolet Traverse LT SUV (A59231)
2012 Chevrolet...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
