Old_New Miller Bobcat 225--Few Questions
   / Old_New Miller Bobcat 225--Few Questions #1
loudhornsrule
Hello, i just bought a used lpg welder. I needed to know how long it will run on a full Tank, and can I hook up a bbq grill bottle with some sort of adaptor? Not sure of the size of my tank, but It looks like a forklift bottle. Thanks
   / Old_New Miller Bobcat 225--Few Questions #2
Forklift bottles have a dip tube so they pull liquid out of the bottom of the tank. BBQ tanks pull gas of the top of the tank.
No clue if that welder is setup to run on liquid or gas propane, but you need make sure you feed it the right fuel it's designed for if you want it to work.
   / Old_New Miller Bobcat 225--Few Questions #3
An LPG motor that size (~20hp) will use ~1 gallon per hour. Unless doing small jobs, a 20 lb. bottle (~4 gallons) will freeze up and not allow gas to escape. At 40 degrees F +, gas or liquid should be ok. Some smaller engines are a bear to get started on LPG the colder it gets.
A liquid draw setup has a vaporizer unit added (near oil filter?) to allow engine heat to convert the liquid to gas.
   / Old_New Miller Bobcat 225--Few Questions #4
I had a Lincoln Ranger 8 that had an LPG conversion. It worked well in the summer but was very poor starting in the winter. Didn't take long for the coolness of LP to wear off and I had it converted it back to petrol.
   / Old_New Miller Bobcat 225--Few Questions #5
Ditto for my Hobart champion i had, also pain when mobile welding had to carry spare tank.
   / Old_New Miller Bobcat 225--Few Questions #6
Yep, Me too. Worked much better to use non ethanol fuel and let it weld.
2001 Ford F150 (A50121)
2001 Ford F150...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2015 INTERNATIONAL LONESTAR SFA 6X4 ROAD TRACTOR (A52706)
2015 INTERNATIONAL...
WACKER NEUSON (A55745)
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
