Review on TSC Electric Log Splitter- Earthquake brand- 5 Ton
   / Review on TSC Electric Log Splitter- Earthquake brand- 5 Ton #1
Cavjock22
Seabrook, TX
Kubota M6060, Bushhog 3210, Deere offset disk, Deere B drill, forks, bucket
Don’t hesitate. This thing rocks. It’s built for seasonal use. I would not recommend for daily or even weekly use but for us southern folks who need to split would on occasion it fits the bill. Splitter comes pre-filled with hydraulic oil. Takes about 10 min to put together with one wrench size. Only negative is the unit sits very low. It will kill your back if you use it as built. I used it on my tailgate. Would probably recommend saw horses as well. Didn’t find a log she wouldn’t split. Used the better part of the morning. It cycles fast enough to grab and setup the next log.. Did I mention it’s under $300.00
Below are some quick videos..
December 27, 2018 - YouTube
   / Review on TSC Electric Log Splitter- Earthquake brand- 5 Ton #2
I have oak on my property that laughs at a 27 ton splitter.... 5 ton may be good for soft woods though...
Dale
   / Review on TSC Electric Log Splitter- Earthquake brand- 5 Ton #3
This toy has been discussed over and over again. It comes in various colors with various names including one version from HF. Some of us think it might have a use inside the house near the stove for that last split of chunks that are just a bit too big.
   / Review on TSC Electric Log Splitter- Earthquake brand- 5 Ton #4
Ramsplitter HV16-4 16-Ton Horizontal / Vertical Electric Log Splitter
I bought one of these a few years back and love the fact that is is quiet, odor free and powerful but, it did, does have QC issues.
Basically, I have had the entire unit rebuilt as various parts and pieces failed and were repaired with stronger, better metal.
My welder friend is expert at his work, has done all the repairs and now the rig is pretty indestructible. YMMV.
   / Review on TSC Electric Log Splitter- Earthquake brand- 5 Ton #5
^^^ $1,200 ????
I paid half that for my used 28 ton Huskee. New 20 ton gas models are generally under $900 in many places.
It may be OK if you're always in range of an outlet. Other wise you'd need a healthy generator to take it out in the field where the wood is.
   / Review on TSC Electric Log Splitter- Earthquake brand- 5 Ton #6
I remember seeing one in the Grizzly catalog that seamed to be cheaper than I had ever seen for one of these small splitters. I've toyed with the idea of getting one to make kindling for starting a fire. Right now I just use a small axe. I think that the axe is faster so I always pass on getting one. But I also split my own wood so I make it close to the size I want. If I was buying split wood I could see a bigger need to split large stuff in half.
   / Review on TSC Electric Log Splitter- Earthquake brand- 5 Ton #7
^^^ $1,200 ????
I yard all my firewood logs behind my workshop so I am always near an outlet.
I also rewired the motor to use 220 volts which increased the power
and decreased motor heat.
   / Review on TSC Electric Log Splitter- Earthquake brand- 5 Ton #8
I use one of these: Manual Slide Log Splitter
Works better than you'd expect by looking at it. I've cracked some fairly big stuff. Weld between the shaft and wedge broke but that's been fixed now.
   / Review on TSC Electric Log Splitter- Earthquake brand- 5 Ton #9
Kindling Cracker is the easiest way to make kindling.
https://www.northerntool.com/shop/tools/product_200676883_200676883
ALLISON TRANSMISSION (A55745)
ALLISON...
2012 SANY SRC 840 4x4x4 40 Ton Rough Terrain Crane (A60460)
2012 SANY SRC 840...
2018 John Deere TX (A53317)
2018 John Deere TX...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2016 Lincoln Navigator SUV (A59231)
2016 Lincoln...
