B2650 rear pto locked up?
   / B2650 rear pto locked up? #21
What's bad about it? The bearings are bathed in the hyd oil so if they are rusted up there's a larger problem.
That seal looks almost factory new to me, just a little dirt stuck to the grease that I can see.
   / B2650 rear pto locked up? #22
Don’t know if they have a brake or not. I do know mine doesn’t turn no matter where I put the lever. Key on or off, rear,middle selected or both selected on the range lever. Only turns with engine running and on lever pushed.
All fixed $3300 later!
   / B2650 rear pto locked up? #24
Glad its fixed.
What parts were damaged and is there a guess as to the root cause of the problem?
I don't have the invoice yet but they said it cracked the rear housing around the pto that is what was leaking and a few gears where missing teeth which is why it did not want to switch on/off. What a mess.
   / B2650 rear pto locked up? #28
I hope you have watched the Everything Attachment Video on how to cut and measure a PTO shaft before you use the Snow Blower again.
A few times to say the least!
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
1608 (A57192)
1608 (A57192)
2026 Anvil AT7X15TA2 16ft T/A Enclosed Trailer (A56859)
2026 Anvil...
SUV (A59231)
SUV (A59231)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
