B2650 rear pto locked up?
   / B2650 rear pto locked up? #21
What's bad about it? The bearings are bathed in the hyd oil so if they are rusted up there's a larger problem.
That seal looks almost factory new to me, just a little dirt stuck to the grease that I can see.
   / B2650 rear pto locked up? #22
Don’t know if they have a brake or not. I do know mine doesn’t turn no matter where I put the lever. Key on or off, rear,middle selected or both selected on the range lever. Only turns with engine running and on lever pushed.
All fixed $3300 later!
   / B2650 rear pto locked up? #24
Glad its fixed.
What parts were damaged and is there a guess as to the root cause of the problem?
I don't have the invoice yet but they said it cracked the rear housing around the pto that is what was leaking and a few gears where missing teeth which is why it did not want to switch on/off. What a mess.
   / B2650 rear pto locked up? #28
I hope you have watched the Everything Attachment Video on how to cut and measure a PTO shaft before you use the Snow Blower again.
A few times to say the least!
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2014 Freightliner 105' Bucket Truck (A56436)
2014 Freightliner...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Utility Cart (A59228)
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2025 Future 750 Remote Control Crawler Mower (A56859)
2025 Future 750...
