Grading New to me Kubota M59
   / New to me Kubota M59 #121
56805209730__CD9AAED5-4C2E-4297-8FB6-B09D6743282C.JPG56805275891__7B535C16-BC6D-421E-869B-BEEFA2B199EA.JPG
January Started good......then sheered all the studs pushing snow!! 4 hrs later got the broken studs out and some temporary bolts in and got back to the house. -22 C . I am getting good at fixing ****!!!
   / New to me Kubota M59 #123
No - I had 2.5" spacers for chains - they were all torqued to spec....but with all the snow ploughing (my drive way is 1 km long) they must have slowly came loose, then sheered right off! I checked the other side and it was loosening up as well. So I took the other side off as then spent a few hours yesterday making the chains are super tight. Tried out a bit and they do not seem to be rubbing.
I guess it's my bad for not checking to see if things came loose....I wish the spacers were made of steel and maybe I should have ordered 1" or 1.5".
   / New to me Kubota M59 #124
I installed studs on fronts of my little Mahindra. Should have gotten chains. Minimal improvement. Need for steering, not traction as I have chains on rear.
I would imagine the heavier the machine improves the difference they make. I moved snow today with them and did not spin a tire. It’s early yet, but I can see they are making a good improvement. Your “need for steering” sounds like a traction issue as well. Also one of the reason I bought them. The tractor would keep going forward while the R-4s are turned all the way to one side. LOL
   / New to me Kubota M59 #127
What I have found the tractor will push straight no problem - so what i have been doing it running straight down the middle first and then running up each side afterwards with the blade angled and up a bit. Seems to work a little better for me. With the blade on and angle it wants to move the front end all over the place. I do not have chains on the front but i am very wary on how hard it would be on the front end. Hope you guys don't mind me chiming in here....LOL
   / New to me Kubota M59 #128
Just smashed into a 12' stock panel when the plow caught a bunch of frozen hay in the snow and knocked the front end over a foot. Wife will be mad, but it could have been a vehicle or the side of our barn. All snow does is wear out your tractor, then melt in the spring. Broke a link on my cheap front chains, 1/2 hour to mend. I hate plowing snow, especially with my own equipment. I rather move dirt.
   / New to me Kubota M59 #130
It is hard to get a backhoe stuck/stranded. :thumbsup:
Just for the ability to get yourself out of a jam, a BH is worth it.
Very hard to get stuck, but done it twice. Scary.
Good reason not to sell my excavator and have good cables and chains on hand.
(10) UNUSED SDLANCH 2.5CMX3M RATCHET STRAPS (A58375)
(10) UNUSED...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
2019 Ford Transit Connect Cargo Van (A56858)
2019 Ford Transit...
Forklift (A59228)
Forklift (A59228)
2022 Chevrolet Express (A57148)
2022 Chevrolet...
