Grading New to me Kubota M59
   / New to me Kubota M59 #121
56805209730__CD9AAED5-4C2E-4297-8FB6-B09D6743282C.JPG56805275891__7B535C16-BC6D-421E-869B-BEEFA2B199EA.JPG
January Started good......then sheered all the studs pushing snow!! 4 hrs later got the broken studs out and some temporary bolts in and got back to the house. -22 C . I am getting good at fixing ****!!!
   / New to me Kubota M59 #123
No - I had 2.5" spacers for chains - they were all torqued to spec....but with all the snow ploughing (my drive way is 1 km long) they must have slowly came loose, then sheered right off! I checked the other side and it was loosening up as well. So I took the other side off as then spent a few hours yesterday making the chains are super tight. Tried out a bit and they do not seem to be rubbing.
I guess it's my bad for not checking to see if things came loose....I wish the spacers were made of steel and maybe I should have ordered 1" or 1.5".
   / New to me Kubota M59 #124
I installed studs on fronts of my little Mahindra. Should have gotten chains. Minimal improvement. Need for steering, not traction as I have chains on rear.
I would imagine the heavier the machine improves the difference they make. I moved snow today with them and did not spin a tire. It’s early yet, but I can see they are making a good improvement. Your “need for steering” sounds like a traction issue as well. Also one of the reason I bought them. The tractor would keep going forward while the R-4s are turned all the way to one side. LOL
   / New to me Kubota M59 #127
What I have found the tractor will push straight no problem - so what i have been doing it running straight down the middle first and then running up each side afterwards with the blade angled and up a bit. Seems to work a little better for me. With the blade on and angle it wants to move the front end all over the place. I do not have chains on the front but i am very wary on how hard it would be on the front end. Hope you guys don't mind me chiming in here....LOL
   / New to me Kubota M59 #128
Just smashed into a 12' stock panel when the plow caught a bunch of frozen hay in the snow and knocked the front end over a foot. Wife will be mad, but it could have been a vehicle or the side of our barn. All snow does is wear out your tractor, then melt in the spring. Broke a link on my cheap front chains, 1/2 hour to mend. I hate plowing snow, especially with my own equipment. I rather move dirt.
   / New to me Kubota M59 #130
It is hard to get a backhoe stuck/stranded. :thumbsup:
Just for the ability to get yourself out of a jam, a BH is worth it.
Very hard to get stuck, but done it twice. Scary.
Good reason not to sell my excavator and have good cables and chains on hand.
New/Unused 14ft Bi-Parting Iron Gate (Cow Design) (A57454)
New/Unused 14ft...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
2012 Chevrolet Equinox SUV (A56859)
2012 Chevrolet...
2011 Ford F-750 Etnyre 2,000 Gallon Asphalt Distributor Truck (A56858)
2011 Ford F-750...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2020 CAT D6K 2XL (A55272)
2020 CAT D6K 2XL...
