Moving a Utility Trailer with a 2 wheel tractor
/ Moving a Utility Trailer with a 2 wheel tractor #1
TimberXX
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I need to store a 1000 lbs trailer off the driveway, and want to push and pull it with a 107d. Its relitively flat, but rough enough that I can't do it myself.
Any one have any experience? I would fill the tires.
thx
/ Moving a Utility Trailer with a 2 wheel tractor #2
I wouldn't think you'd have any trouble on flat ground if it's just 1000 lbs.
/ Moving a Utility Trailer with a 2 wheel tractor #4
If your tractor has reverse, I would rig up a hitch on the front.
/ Moving a Utility Trailer with a 2 wheel tractor #5
Yeah I wouldn't buy weights just for that purpose. Even a small walk behind has much more pushing/pulling ability than the average man. If you can even budge it by hand, your tractor shouldn't have any trouble with it on level ground.
/ Moving a Utility Trailer with a 2 wheel tractor #6
IMG_1199.JPGIMG_1200.JPGI built a dolly to use the BCS to move stuff around. The log splitter, trailers, use the ball. If I'm pulling a spreader I replace the ball with a seat and ride. It does work a lot better to pull the trailer than push, and flat ground would really be nice.
thats a great idea. I was considering an over sized pneumatic caster, but your setup looks much better.
How big is the trailer that you move?
/ Moving a Utility Trailer with a 2 wheel tractor #8
I use the tow coupler (available from Earth Tools) and strap or bolt a short piece of 1 1/4" pipe to the trailer tongue to receive the coupler. I like this method because it uses the tongue weight of a trailer, log splitter, etc, applying weight to the BCS directly for better traction. I also have a sulky and can tow behind that too, which would be like cmyoung2's setup. That works great for longer tows and gives me a seat. Earth Tools
I forgot to add...
I use a small 40" x 48" trailer with wood sides added. I've had it heaped with wet clay and sod, and with me on the front bench seat it was probably approaching one ton. On level ground it drives fine (usually only loaded with half that weight), but I have to step off and steer from the side (walking) on slight hills.
/ Moving a Utility Trailer with a 2 wheel tractor #9
There is a Youtube video on the Bad Day At Work Fails, about some Asian Family on an outing with their two wheel tractor, attached to a trailer with them on it. I think the driver falls off, and the thing is going in circles for what seems like the longest time, with neither the people still on the trailer or on the ground being able to do anything about it. Finally it crashes. Quite sad actually.
/ Moving a Utility Trailer with a 2 wheel tractor #10
My trailer is a 5x8, but it is very heavy, 1200+ lbs empty. I seldom have to move it with the BCS, and most of my ground is not anywhere near either level or smooth. Mostly it is for the log splitter, garden wagons, seed spreader.
/ Moving a Utility Trailer with a 2 wheel tractor #11
Went to YouTube to find this and after searching for Bad day at work Fail realized it may take years to find this particular video, so watched first one just for giggles and grins, above mentioned video was part of that compilation at 10 minutes in...
Bad Day at Work Compilation 2019 Part 2 - Best Funny Work Fails Compilation 2019 - YouTube
/ Moving a Utility Trailer with a 2 wheel tractor #12
The 'Bad Day at Work Fails' segment begins at about 7:05. The whole thing is 10 minutes.
/ Moving a Utility Trailer with a 2 wheel tractor #13
Thanks for doing the leg work. I almost bought one of those same engines a few weeks ago at auction and posted why I could not figure out why it had a headlamp.
Anyway, it sold CHEAP (at Auction) and I completely forgot about the on-line cut off time!
/ Moving a Utility Trailer with a 2 wheel tractor #14
I was thinking about that two wheel tractor and trailer video when reading this thread. :)
/ Moving a Utility Trailer with a 2 wheel tractor #15
Can you imagine just for a moment, considering what life would be like, if that was your only family transportation. Well, maybe their second car is an Oxen. Heck, maybe they are the most oppulant in their village!
/ Moving a Utility Trailer with a 2 wheel tractor #16
Two wheel tractor - YouTube
Off to WalMart.
Power of Kubota 2 Wheel Tractor Plowing Farm Field​ Take potatoes in Cambodai - YouTube
For you Orange types.
Julia odwozi pszenicę. Młocenie bizonem - YouTube
The guy getting off the open platform combine and using a tester to determine the moisture content took me back about 50 years @ 2:22 and is called the teeth or bite moisture test. Dad would use a knife after it started passing the "bite" test. You watched how far the two pieces of the grain jumped from the knife blade to judge moisture content. You could tell from the job the tractor drive did this was not the first time she had spotted the grain trailer. I expect this was a test run that the guy cut since it was not a full load and most likely was used for feed on the fly. Not sure but I thought he said '21' when he bit into the grain.
Farmers of yesteryear had smaller equipment budgets in the USA.
ford 850, do you have a photo of your setup? I like the idea of using the tongue weight on the tractor
/ Moving a Utility Trailer with a 2 wheel tractor #18
I thought I had some pictures but I can't find any. It's -15 degrees this morning and a foot of snow so I'm not going to get any new pictures, but the link I posted to Earth tools has some that will give you ideas. There are a couple pictures and a few paragraphs describing the tow coupler and pipe on that page I posted, and a couple pictures of small trailers/carts with the coupler here: Earth Tools
I thought out using uni-strut to mount the coupler in a similar way. Great group here, thanks all.
/ Moving a Utility Trailer with a 2 wheel tractor #20
On that small trailer I talked about above, it had a ball coupler for regular road use. I originally bought the trailer to haul my BCS to a couple locations for tilling and it worked fine. Funny that years later the roles were reversed and the BCS now hauls the trailer. Since I hauled quite a few heavy loads and when I sit on the front of the trailer (bench seat along front wall) it adds that much more weight to the tongue and was beginning to bow the original u-channel. Last year I upgraded the trailer by removing the tongue and replacing it with a length of square tube going all the way to the back. The tube is sized to accept standard 2" trailer hitches and I can add one to the rear to pull an additional cart, wagon, or wood splitter behind the trailer. I left the ball coupler off the front of the tongue and added a 1' piece of 1 1/4" pipe for my BCS coupler. I can also add a trailer hitch to the front of the tongue and attach that behind my sulky or larger tractor. It looks like a train when the BCS is pulling the sulky, which is pulling the trailer, which is pulling the large gorilla wagon. For most heavy hauling I just connect the trailer directly to the BCS coupler.
2014 Ram 1500 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 Crew...
Deere 35G (A53317)
Deere 35G (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
(1) 300 GALLON & (1) 330 GALLON POLY TOTES W/CAGES (A60432)
(1) 300 GALLON &...
UNUSED SDLANCH SDLWC WOOD CHIPPER (A60432)
UNUSED SDLANCH...
