Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!)
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #1
snymat68
Monroeville, PA
RK24H, Gravely 8123
[**DISCLAIMER**]
I do not condone or suggest anyone lift more than the rated lift capacity stated by the manufacturer.
I will not be held responsible for any equipment damage, injuries, or deaths that may occur from operating outside of the manufacturer's recommendations.
The following are simply data that I collected for my own knowledge, that I also decided to share with tractor community.
Now that that's out of the way... :)
I was curious what the ACTUAL lift capacity of my new RK24 is, with the L75 front end loader with SSQA and 50" bucket installed.
The literature states 947 lb at full lift height (75"). But we all know that is with a safety factor and wiggle room figured in.
It was also unclear as to whether that number was with or without the SSQA and bucket installed.
I purchased a "crane scale" from Amazon that can measure up to 2000 lb. It has a handy feature where you can set it to hold the highest reading.
https://smile.amazon.com/gp/product/B00ZE7492E/ref=ppx_yo_dt_b_asin_title_o03_s03?ie=UTF8&psc=1
(click to enlarge)
I welded a shackle to a plate and bolted it to a 48" tree stump with 5/8" x 8" lags, as an anchor point.
I attached the scale to the anchor, and then to the bucket with a 5/16" chain.
Due to there being a minimum height needed to fit all that in, I don't have any data points right near the ground, but one can assume they'd have even higher forces.
The tractor was on level ground, even with the top of the stump, and all tests were done with the chain vertical.
I tested in 6" increments, from 20" to 74", as measured from the top of the stump (ground level) to the center of the pivot pin.
I took two measurements at each height. One at idle (~1350 engine RPM) and one at PTO RPM (~3000 engine RPM).
For each test, I applied slow, even pressure against the scale to avoid spikes, and I held the joystick for several seconds until the reading stopped climbing.
Between each test I relieved the pressure on the chain, adjusted the chain length if necessary, zeroed the scale, adjusted the RPM if necessary, and ran the next test.
Here's a picture of my setup.
(click to enlarge)
Remember, these numbers are with the bucket and SSQA installed, so these data are a close representation of what material can actually be lifted with the bucket.
Let's just say I was pleasantly surprised with the results. :dance1:
This thing is a beast for it's size.
Here are my findings. Enjoy!
(click to enlarge)
EDIT: See post 47 for updated/corrected findings (or the chart below): https://www.tractorbynet.com/forums...-capacities-rk24-post5412074.html#post5412074
Updated/corrected findings:
(click to enlarge)
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #2
Very impressive for sure. I have the RK37 and would love to test it that way. Great job!!!!
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #4
That’s awesome! Thanks for sharing. I wonder if the mfg lift capacities have anything to do with stresses on other parts of the tractor, such as the front axle?
I'm sure everything comes into play, as well as safety.
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #6
Very interesting. I'm not sure I would want to pick up 1500 lbs with that size tractor, but it is clear that it has ample safety factor built in. Picking that much up and being able to maneuver with it are two different things. There is also the possibility of bending things and inducing excessive wear in the front axle. All reasons to have some restraint when unleashing the little tank on a project.
I definitely agree, but knowing the limits is still good info to know.
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #8
Those are some mighty impressive numbers. I wonder how hard on that front end those loads would be for such a small tractor. In any case I am surprised at those readings.
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #9
In some ways I am not entirely surprised. The loader on my Ford is rated at 1200 lbs, but it will easily pick up the rear of the tractor with 880 lbs of ballast in the tires and a 6 foot brush hog hanging off the back.
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #10
Nice looking chart and data presentation! As an engineer, I have great appreciation for data presented in such a way that is easy to consume and postulate relationships/conclusions.
I don't think it was mentioned, but did you stop when the rear tires began to lift, or did the bucket just stop moving?
I had the backhoe installed. The loader wasn't gonna lift that. :)
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #12
As someone who works with load cells and calibration a lot, a couple things about the results concern me from a data perspective. First is the kink/shift between 50" and 56", any guesses on that? Second are the constant loads from 38" to 50" and 56" to 62". Both of those suggest that either something fouled or the scale was sticking or has very coarse sensitivity. Finally, the shape is not consistent with the way a loader curve should look (most tractors have a loader curve in the owner's manual you can lookup for an example). Because the loader arms are a simple linkage, you should see a smooth parabolic shape to the lift curve. There should not be kinks or flat spots.
Was the chain always vertical? Did you adjust the position of the tractor so that the loader was directly above the pull point at each measurement? That could possibly affect the results but I still suspect some sort of fouling or sensitivity issue at play.
BTW, I think this is a great idea, just saying the curves don't look the way they are supposed to, so something isn't right.
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #13
Try lifting something 1550lbs, that scale is nowhere near accurate.
I tried to keep the chain vertical for all tests, but there was probably a little variation.
The scale is accurate. I lifted several known weights with it and it was right on.
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #15
I agree that something seems off. Lifting 1600# with a loader that only weighs 480# that INCLUDES the bucket. And being THAT much over the MFG's rated numbers.....something isnt right.
The MFG's numbers are calculated based on geometry, cylinder size, and hydraulic pressure. Nothing more, nothing less. Everyone often "claims" under rated numbers, or reduced numbers for "safety" reasons or stability, or front axle, or whatever. None of that is true. Its simply a calculation, and is close to real world numbers. The problem is most people dont know how to interpret the MFGs specs. And when their loader is "rated" for XXXX pounds to max height....and they can lift several hundred more than that at a modest height......people start throwing around the word "underrated". And too many people try to justify it with the safety, stability, etc excuses. When in fact it is nothing more than a failure to understand the "rating".
That said.....I'd be curious to know the bore x stroke that they are using for the lift cylinders. And further....if you want an actual calculation and some understanding....I need THREE simple measurements (to start) to go along with cylinder specs. If you look at the side of the loader.....the lift cylinder has two pins. And the boom where it attaches to the upright post is a third pin. With cylinder completely collapsed.....(might raise the front of the tractor) these three pins form a triangle. I need the lengths.
I'll get you the specs and measurements tonight, but only if you promise to show your work. I'm interested in the equations/math used. :)
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #17
No problem.
But the critical key is cylinder bore diameter. Cause without the MFG spec, its difficult to measure without guessing.
I am betting 40mm bore
No problem.
I have bore gauges and a saw! LOL It's still under warranty. "No sir. I don't know how that cylinder failed. One minute it was fine, the next it was in two pieces!" :laughing:
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #19
At least you have a good sense of humor.
The math (if you like math) is the easy part. Its actually understanding the concepts and how to apply the math that give most people fits.
/ Here are the ACTUAL Lift Capacities of the RK24 L75 FEL @ Varoius Heights (w/ Graph!) #20
Wouldn’t it be a lot easier to figure out the ratio between the distance the loader pins move and the cylinder stroke? That method would fail to account for it being stronger at the bottom and would instead give an average. And you’ll need to know the psi the tractor is putting out.
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2009 Ford F-150 Pickup Truck (A59230)
2009 Ford F-150...
2022 NIFTY TM34TE-MK1B TOW BEHIND BOOM LIFT (A60429)
2022 NIFTY...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
