3 Bottom rollover plow (IH140 plow) questions
   / 3 Bottom rollover plow (IH140 plow) questions #21
Are your wheels still set like they are in this photo, if so you still have some adjustment left? Leave the centers as they are but switch the outer rims from side to side. The mounting ears on the rims are also offset and by switching them you will gain some more width.
I find it interesting how different a manufacturer can make things and why. I have been wanting to widen my tractor stance. Just haven't figured out how to support and make the change.
Point of my post is this;
Look how mine came from the dealer, note the valve stem compared to what partyhound's looked like. At the rim's widest stance the valve stem is still on the outside. Distance inside to inside is 48.5", but I still want that extra 3-4 inches.:)
   / 3 Bottom rollover plow (IH140 plow) questions #22
A flat level concrete floor would be best. Take your time, tipping the wheel only slightly if necessary to roll. IF it decides to go over get out of its way and let it go.
I’ve moved lots of fluid filled tires in my life. I’m only 5’ 6” and the big row crop tires that were TALLER than me were the EASIEST because of leverage.
I’ve only had one get away from me so I just let it go. Had to use the tips of the forklift to stand it up for me. Lol.
Think it out and be careful.
   / 3 Bottom rollover plow (IH140 plow) questions #24
Thanks, luckily mine aren't filled yet so it will be easier than what partyhound will have to deal with.
Yeah Lynn, yours are a lot different than mine. I think mine are 16.9-30. Yours the same?
   / 3 Bottom rollover plow (IH140 plow) questions #26
   / 3 Bottom rollover plow (IH140 plow) questions #27
Mine are 14.9-28
Little side note,
It's upsetting, but when I bought mine I could have bought the 7320 for less than I paid for the 6620. The reason I didn't is two fold. I only lived on 6 acres at the time with no plans to move. Really didn't need a tractor that big. Second reason is it had been on the lot for some time and I didn't want a tractor that everyone had been testing out on the lot.
In hindsight I should have just bought the 7320.
   / 3 Bottom rollover plow (IH140 plow) questions #28
These are still not at there widest setting. The loops on the rim would be on the outside of the inner disc. As for the valve steam location it depends on how the tire is mounted on the rim being a directional tread.
   / 3 Bottom rollover plow (IH140 plow) questions #29
Well duh!! Now that you said it, it makes perfect sense. I'd like to think I was smarter. :laughing:
I knew there was more room by adjusting the rim, but sure didn't know about how the tire was mounted.
   / 3 Bottom rollover plow (IH140 plow) questions #30
I just found these plow setup instructions from Ken Sweet.
The Instructions From a JD plow owners manual, the tire settings on the tractor are the major determining factor in how much the front plow cuts (1-2-3-4 bottom plow all the same) and keeping it centered with the tractor.
From the inside of the right rear tire rubber to the center of the drawbar you need:
23 inches for 12" bottom plow
25 inches for 14 inch bottom plow
27 inches for 16 inch bottom plow
We have used these initial setttings for decades and they works on all brands plows and all tractors--We have found that this in the single most important initial setting when mounting a plow.
Sweet Farm Equipment - New & Used Farming Tools & Equipment | Tractor Equipment, Implements
---Ken Sweet
Sweet Farm Equipment Co. *Canmer and Munfordville, Ky*
I don't know where he posted them.
   / 3 Bottom rollover plow (IH140 plow) questions #31
---Ken Sweet
Those measurements are for one way plows not rollover I believe, but may still apply.
   / 3 Bottom rollover plow (IH140 plow) questions #32
Yes, wheel spacing is the cause of his problem.
For all those posting remember the OP has a 316 rollover plow.
This is one HEAVY plow. Without the stabilizers it wil most certainly swing side to side pretty intensely and probably catch a tire. That has been my experience.
Mike
   / 3 Bottom rollover plow (IH140 plow) questions #33
Mike
In which case stabilizers should be set so the implement has free movement WITHOUT hitting the tires.
   / 3 Bottom rollover plow (IH140 plow) questions #34
THEPARTYHOUND- I believe, on this machine only 2 of 3 top-link positions will work with draft. One of those positions is for heavy load (the middle hole) and one is for normal load (lower hole). I wonder if one or the other of these top-link locations might help automatically maintain plow depth better. Just a thought.
   / 3 Bottom rollover plow (IH140 plow) questions #35
The tractors that I mouldboard plowed with did not have stabilizers to loosen unless you removed the sway blocks which we never did.
When the spacing is set the plow needs to run evenly not be allowed to walk around.
Our 4 bottom were IH fast hitch which are quite a bit different but the plow was not allowed to swing free side to side.
Also ran a 4 bottom turn over on a 1206 it was setup with as minimal swing as possible.
Our 5 bottoms where semi-mounted with a side hill hitch (adjustable) and a linkage turned rear furrow wheel.
None of these where allowed to swing fre.
I did check, if the stabilizers were not used, the plow could swing into the rear tires. micdelbo is right, this plow is HEAVY! Somewhere close to 2500 lbs according to the scales at the truck stop. The stabilizers have an oval hole to allow some movement without allowing the tool to swing the lower arms into the tires, which is what I have been using and it seems to be working pretty good. I suspect that the plow is following inline pretty good, but maybe once it's in the ground I could remove the stabilizer to see if that changes the way it tracks. I would not want to drive around the hills, ditches, bumps, etc without the stabilizers and the plow in the air. I'm sure it would violently bang from one tire to the other!
Wooly, I did read up on that. I have been running it on the lower of the two pins. I guess it would be worth a try to see what it does on the middle pin, but I was assuming the lower pin would give me the most sensitivity which kinda seems like a good thing. It does seem to be holding it's depth well, except when I run into one of the few rocky areas that I have in the field. Then it seems that it works best to just lower the draft control and let it sink in till I start slipping tires, then give it a little more draft control to put some weight back on the tires. Once it bites into the rocky soil, it keeps it's depth pretty well.
   / 3 Bottom rollover plow (IH140 plow) questions #37
THEPARTYHOUND, any luck widening your tires?
No Wooly, I still didn't get that done. I just went ahead and finished plowing with it set up the way it was. I never have as much time in the evenings as I'd like to have. It may end up being a weekend project.
   / 3 Bottom rollover plow (IH140 plow) questions #39
I understand. Glad you're making progress on the field. Just be careful swapping those tires. If you think of it, post back if/when you get them swapped. I'm curious to know if that will allow you to get to full, 3 plow use. And I'd like to know how this tractor handles all 3 plows in the ground. Best of luck.
FWIW, it has pulled all 3 plows in the first row. It really didn't seem to be any different than just the 2 of them. The hills I'm plowing on give me the most trouble in terms of both traction and power. In hindsight, it may have made sense to set up so that I was plowing across the side of the hill with my tires in the empty furrow on the uphill side.
All told, however, this tractor handles this plow well. In 4th gear, low range you will never run out of power. It is only a matter of keeping traction. I have done 98% of my plowing in Med range 1st gear (which can lose power occasionally) and even a very little bit in 2nd. I'm plowing uphill in soft sandy soil and only once did I lose traction to the point that I had dug 4 holes and then had to back up and pull the plow out and reposition. I'm running 20 psi in the back tires. They came from the dealership with single digit pressures, which I didn't notice till I mounted the 2500 lb. plow and the tractor felt like it was going to tip over on uneven ground! At 20 psi, the tires handle the weight well and provide oodles of traction. In fact, it surprises me how much traction I get with this setup at times!
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2016 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2016 CHEVROLET...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
